Old 03-11-2018, 09:15 AM
remy30006 remy30006 is offline
Default exhaust manifold difference?
I have the correct 64 drivers side exhaust manifold for dual exhaust but I have a passenger side which numbers come out to be a 66 with the heat riser valve. Are the 64 and 66 manifolds the same except for part numbers? Will the 66 bolt up and work?
Old 03-11-2018, 12:49 PM
60sstuff's Avatar
60sstuff 60sstuff is offline
The 64 heat riser “weight” is different from the 65 and newer style.
Below is a NOS 64 RH exhaust manifold (first 4 pics).
Last pic is a pair of 65 manifolds.
Same bolt pattern on all of them.
Chris.
ID:	477856   Click image for larger version
ID:	477857   Click image for larger version
ID:	477858   Click image for larger version
ID:	477859   Click image for larger version
Old 03-11-2018, 04:25 PM
bill ryder's Avatar
bill ryder bill ryder is offline
Hello Chris. I see your 64 manifold does not have the little anti rattle spring but the 65 does. Did they not use that spring in 64?? I don't know. "Bill"!
Old 03-11-2018, 05:45 PM
I'm not too worried about the heat riser, I'm probably going to make sure it stays open. I'm more worried about flow and if it is basically the same if I go with the 64 on one side and 66 on the other.
Thank you for all the help and pictures!
Old 03-11-2018, 07:03 PM
60sstuff's Avatar
Mr. Ryder,
I purchased the NOS 64 manifold as shown. I’m sure it had the anti rattle spring at one time.
I have an NOS Spring and my MPC shows 63-67 All exc. T/6 #521580.
Chris.
ID:	477874   Click image for larger version
ID:	477875   Click image for larger version
Old 03-11-2018, 08:44 PM
bill ryder's Avatar
As always, Chris, many thanks!!!! "Bill"!
Old 03-11-2018, 09:17 PM
If you were to put a '64 and a '66 manifold side by side you wouldn't be able to see any difference in the manifolds themselves, the manifold castings are pretty much identical. The overall design didn't change for quite a few years. Dual exhaust and single exhaust applications both used the same manifolds.
You're good.
Old 03-12-2018, 06:54 AM
Thank you! Were the down pipes 2 1/2" from the manifolds in 64?
Old 03-12-2018, 06:33 PM
Tom Vaught's Avatar
Boost Engineer
I remember 2-1/4" but that was a long time ago with a lot of header swaps after those days.
Tom V.
Old 03-12-2018, 08:20 PM
John V. John V. is offline
For '64 GTO
Head pipes were 2.25"
Mufflers were 2.25" inlet and 2.00" outlet
Tailpipes were 2.00"
Same exhaust for auto and manual trans
'65 was different.
