Old 03-31-2018, 12:49 PM
Jim Robertson's Avatar
Jim Robertson Jim Robertson is offline
Default 74 replacement Front Bumper and filler panel
Where do I go to get a front bumper for the 74-75 bird/trans am? I could find a few older posts on here about this subject but nothing current. What is the latest news on frt bumpers? looking for any material as long as the fit/look is correct.
Jim
www.raceV8s.com
1972 Trans Am drag car, 3300lbs, 468 ci, Iron D ports, 428 block, 9799103 crank, 9.48 @ 143mph, 6.0 @ 114mph in the 1/8th.
Old 04-01-2018, 10:54 AM
74 SD455 Formula 74 SD455 Formula is offline
I have a very good used front lower valance for sale if you need one . Its for a 74-75 Firebird.
Old 04-01-2018, 02:37 PM
bluebird455 bluebird455 is offline
I need a couple too, but the last time I got'em online from one of the Big Pontiac parts suppliers, they both disintegrated within a couple of years!
So am gonna very careful this time around.
Old 04-02-2018, 07:04 PM
what does a good used one sell for these days.
Old 04-03-2018, 06:19 PM
ws6speedpaul ws6speedpaul is offline
Default 1974-1975 TA Front End
Not sure if you are in need for this piece.
I took it off a 1974 Firebird about 20 years ago and is complete and not damaged.
Let me know if you are interested either way, thanks.
Paul
Name:	1974 Trans-Am Front Valence3.jpg
ID:	479865   Click image for larger version
Name:	1974 Trans-Am Front Valence2.jpg
ID:	479866   Click image for larger version
Name:	1974 Trans-Am Front Valence1.jpg
Old 04-03-2018, 08:40 PM
critter's Avatar
critter critter is offline
His post says he's looking for a bumper. The bumper is not reproduced so far as I know. It's a metal sub-structure with urethan molded to it. Most are chewed up because Pontiac was still supplying bumper jacks and the owners would get the jack in wrong trying to change a flat. The result was ripped urethane. They also dry out and flake something awful if they're left out in the weather.
How bad is the bumper you have?
12.84 @ 106.89 with street radials.
12.63 @ 108.39 on drag radials.
Old 04-05-2018, 12:52 AM
I have focused on the 70-73 body styles in the past but the 74 is my latest undertaking.
Thanks for the offer 74 SD455 Formula. How much do you want for the lower valance?
Critter, Car has no front bumper at this time. Lost in the shuffle I was told. Local salvage yard had a '75 front bumper a few months ago but it was missing some urethane. Should I pick it up?
No fiberglass or carbon fiber re-makes out there?
Was hoping for a bit better news...
Jim
www.raceV8s.com
Old 04-05-2018, 05:37 AM
sp4spd's Avatar
sp4spd sp4spd is offline
Default 74 bumper
I came across this fiberglass repo when I was doing the resto on my 74 Formula.
http://www.texastransams.com/images/..._75_Bumper.jpg
I was able to fix my bumper so I never bought one of these. They also have the splash pan too.
Good luck with the project!
Scott
70 Buick GS455 4 speed
Old 04-05-2018, 06:42 AM
njsteve's Avatar
njsteve njsteve is offline
The black rubber section is repairable with traditional two-part urethane bumper repair material, similar to how a 70-73 nose would be repaired. As long as the metal backing is rust free you won't run into issues.
Old 04-05-2018, 08:07 AM
sdbob sdbob is offline
My 74 original filler panel cracked after about 30yrs. Bought nos lasted about 15yrs now it's cracked in several places.The material must deteriorate over time. I was wondering how the fibreglas would fit and look?
Old 04-09-2018, 12:40 PM
ladytata's Avatar
ladytata ladytata is offline
I do have a rubber bumper that needs work.
