Old 04-03-2018, 03:08 AM
1965 Pontiac Parisienne's Avatar
1965 Pontiac Parisienne 1965 Pontiac Parisienne is offline
Default '68 GTO frame weld factory???
My friend is working g at his Gto and found these strange weldings .. is this factory?
I’m a 65 B body nut so I’m not knowledge in these a body cars ..
his car has an RH rear rear quarter accident in the 70’s and was parked since in AZ barn...
some pics .. perhaps you have some pics of your frame to see how it’s looking ..
Thx a lot
ID:	479784   Click image for larger version
ID:	479785   Click image for larger version
ID:	479786   Click image for larger version
ID:	479787   Click image for larger version
1965 Bonneville 2 door coupe nightwatch blue AZ car
1965 Bonneville convertible starlight black
1966 Star Chief Coupé
1965 canandian Parisienne custome sport convertible AZ car. „Sold“
1977 california Firebird Esprit [/SIZE][/FONT]
Old 04-03-2018, 08:25 AM
I would say that is sign of accident repair, probably when the car was almost new.
Old 04-03-2018, 09:02 AM
Default Of course 68 GTO
Here’s a pic of his car .“.only“ hit at rear rear quarter .. trunk floor is untouched and the frame isn’t touched ..only the highe är rear ended got a heavy hit .. but perhaps to heavy ..
Old 04-03-2018, 10:24 PM
68pongto's Avatar
68pongto 68pongto is offline
The welds on the rear up and over the rear end are factory. The welds you show up front are not. Frame was bent and straightened/pulled at on time
Old 04-03-2018, 10:53 PM
dataway's Avatar
dataway dataway is offline
Yep I've seen those funny welds inside slots on the rear of frames.
Old 04-04-2018, 04:17 PM
..and this he found today after sanding ...
looks not good ...better let’s say horrible ...looks like the front part was rewelded or cut and weld together with another front part ???
ID:	479952   Click image for larger version
ID:	479953   Click image for larger version
Old 04-04-2018, 05:27 PM
marxjunk marxjunk is offline
he needs a frame...damage on one side butchered and the pic above shows someone put a frame horn on it....terribly...i mean horribly
Mark..
The Goat whisperer
"I spent a lot of my money on booze, crazy women, and fast cars. The rest I just squandered."
Old 04-04-2018, 05:29 PM
1968GTO421's Avatar
Yup, not good. He may want to seek out another frame for his car that hasn't been wrecked.
What MARXJUNK said.
GTOAA--https://www.gtoaa.org/
Old 04-04-2018, 11:07 PM
dataway's Avatar
At least the damage there is forward of the suspension components, so not as structurally important ... but my guess is if you look at the major frame curve behind the control arm area you will find it's been kinked there and straightened. It almost always kinks there if hit hard enough to need the horn replaced. Looks like was done with stick, hooked up to a cheap buzz box, by a bad welder than never cleaned anything first.
The upside is ... it is metal. Anything metal can be fixed by a competent welder. Grind all the mess down to flush metal and reassess the job. A good welder can add the necessary metal, grind flush and you'd barely know it was ever done.
Old 04-05-2018, 12:14 AM
Scott Thelander's Avatar
Default post 1
post 1 picture 4 and 5
I saw those and new the frame was whacked hard
I have seen many a frame cracked... stretched ... collapsed ... there ..
bummer .........
Scott
Old 04-05-2018, 02:23 PM
dataway's Avatar
So there is damage on both sides of the front? Frame horn on one side, and to the rear of the control arm on the other??
If so ... wow, surprised the car wasn't totaled. Surprised there isn't dents in the firewall from the engine being pushed back.
