Old 04-16-2018, 11:21 PM
Sprocket's Avatar
Sprocket Sprocket is offline
Default Valve cover breather grommet
Under the no question is too basic theory...
Got a new valve cover breather grommet. It is a solid piece with no slits, holes, etc. Is there a good strategy or method to open the grommet so that it will allow breathing function yet hopefully minimize the oil getting pushed/sucked out all over the valve covers? Cut a thin opening? Drill a number of holes?
Previously, I have used baffled grommets with great success, but those will not fit this particular setup.
'70 GP Model J
462 Butler ported 87cc Edelbrock D-ports
RPM intake with Holley Sniper 2
CompCams 236/242 hydraulic roller
Tribal Tubes tri-y headers
TH400 13" Continental "Jim Hand Special"
3.50 9" CurrieTrac, 245/45-18 Front, 275/40-18 Rear
Old 04-17-2018, 01:39 AM
66bonne's Avatar
66bonne 66bonne is offline
Can you post a pix of the grommet ? IF it is the design I am familiar with you just cut off the bottom to open it up,
Jim
65 Catalina sedan. Allen Thomas Performance 495. KRE Heads at 310cfm ported by SD Performance, ProSystems Dominator carb on ported Victor intake, P-Dude custom grind hydraulic roller, MSD ignition, 3.50 Moser/Ford rear. F-Glass front bumper by son Rob, rear by the old man and joint effort for trunk lid. 3950# w/driver. Best of 9.5761/139 on 175 shot, 6.01 /114 in 1/8.
Old 04-17-2018, 07:16 AM
steve25 steve25 is offline
The first thing to do is to confirm that if fits tight enough in the hole for it ( hole in the valve cover )to not need any sealer around it !
Most times I seal up the inside with formagasket just to be sure no oil weeps by.
