Old 05-02-2018, 11:42 AM
mikes2nd mikes2nd is offline
Default 1967 passenger fender 150$ 70 Gto Grills
I have a 67 gto front passenger fender for sale, needs a patch, no dents/bashes.
The time spent putting a patch on is less than trying to get a Taiwan fender bent and fitted and dents pulled out and reshipped back
I also have some 70 Gto Grills.
I am in the Akron area.
ID:	482153   Click image for larger version
ID:	482154   Click image for larger version
Old 05-02-2018, 02:24 PM
Scott Thelander's Avatar
Default 70 grilles
70 grilles please send pictures and price
to
scott68gto@comcast.net
thanks alot !
Scott
Old 05-02-2018, 02:25 PM
you want fender pics? or grills?
Old 05-02-2018, 05:48 PM
steve v's Avatar
steve v steve v is offline
Price on the grills? Any damage to them?
Thanks.
Old 05-02-2018, 06:55 PM
gtospieg gtospieg is offline
Just an FYI...the location of the GTO emblem holes on your fender would make it a '66
Old 05-02-2018, 11:57 PM
66 is the same though right?
I would like say 250 for a good set, some tabs cracked but fronts look good.
Old 05-03-2018, 10:47 AM
grill are missing tabs but i don't think the trim needs rechromed, clean these up and fab up some tabs.
Ill take 250$ for this set, the grills from the front look great, no smashed pattern or anything bad.
If your looking for perfect tabs I have a spare set but its gonna cost more.
ID:	482202   Click image for larger version
ID:	482203   Click image for larger version
Old 05-03-2018, 01:25 PM
Default grilles
thank you
thanks for nice pictures
we will pass ....
Scott
Old 05-03-2018, 05:46 PM
[QUOTE=mikes2nd;5877698]66 fender is the same though right?
Technically yes...however the little tab that lines up with the header panel on 66 is narrower...can be removed and one for 67 can be welded on or vice-versa
