| Members Helping Members help Buying a non Pontiac item, transportation help, Handy-man advice, directions, vacation ideas, places to dine, ebay and generally anything you think might help other members. |
Trying to figure out what the ticking noise could be. It started a couple months ago.
Can only hear it when the engine is driving under load, at idle no noise. In park no noise. Seems like it could be coming from the passenger side of the engine. I tried running premium gas, no help. Tick gets quicker as the truck get faster, I laid under the truck while running in park and do not hear any exhaust leaks. Wouldn't a lifter tick all the time? Engine runs and idles great, has always been a gas hog. What could it be, all input welcome, Bob
"Artificial intelligence is no match for natural stupidity". 1966 GTO Post Coupe, 467ci. N/A Pump gas, best 1/4 11.6 118mph 1966 GTO Post Coupe, "The Bright Idea" 535ci. N/A Pump gas, best 1/4 9.56 139mph |
You are in a rusty area. Rusty areas are known for exhaust manifolds and/or exhaust manifold gaskets. It is common on Ford, Chevy, Dodge, Toyota, etc. in rusty areas.
I hope your right, I'm hoping external and not internal fix. The trucks exhaust is probably the rustiest part, it does sit outside all year on the drive way.
If you are going to tackle it yourself, the best way I found to do it is to knock the heads off the bolts, pry the manifold off and remove the rusted bolt like a stud. You will have a nightmare on your hands if you try to remove the bolt as a whole and it breaks off in the head.
This is a common problem with every single manufacturer's trucks from that period. Bad quality manifold bolts and salt spray do not mix..
1976 LeMans B09 Freeway Enforcer, 455/M40 Smokey 1977 Trans Am, 400/M21 Black/Gold Bandit. 44K actual miles 2017 Sierra SLT 1500 Z71 4X4 ![]() 2019 Canyon SLT Crew 4X4 ![]() |
GM and Toyota manifolds are also known to crack. I think Ford too but can't remember.
If not manifolds I’d check the cat conv to make sure it hasn’t broken loose and started rattling.
The More People I Meet, The More I Love My Dogs! |
Well I'm happy that it could be just a gasket and not a lifter. I do not know if this is something I want to tackle without a lift and a welder in case I break a bolt.
Now that I know where to look, tonight I'll get a better picture on how rusty the manifold and bolts are and determine my next step. Thank you to everyone that has given guidance, the Pontiac community is full of great people. Bob From U Tube, it looks like heat from a torch is also required.
So I finely had a chance to slide under my truck and look for an exhaust leak. First thing I notice is a wet spot on the frame, attention has quickly changed to what's leaking.
I have a brake line leak above the gas somewhere, so the exhaust leak is now on hold. Needs brakes, I can live with an exhaust leak for another week or two. Bob
Rusty brake lines are pretty common on these trucks. My '04 2500HD had a line go right next to the fuel tank a few years back, rusted thru. Looking at the rest of the lines going to the abs unit under the drivers floor area was an awakening also....everyone of those lines look like they're ready to go next. Was a little surprised they rusted this bad seeing as we live in NC with very minimal exposure to winter weather/salt brine on the roads here.
I bought a complete pre-bent steel brake line kit from GM that had every line in it for right about $100. Seems like they were a plastic coated steel line so hopefully they'll last a little longer. I was able to replace the line in between the tank & frame w/o removing the tank. Good luck with your repair! Last edited by steve v; 05-18-2018 at 11:46 AM. |
this is exactly what mine did, and no one could diagnose it..pulled the converter loose for something else and it had broken apart and was ticking inside the case...
Mark.. The Goat whisperer "I spent a lot of my money on booze, crazy women, and fast cars. The rest I just squandered."
Is there a way to dump maybe some ATF in the throttle body? All the smoke 'should' pinpoint a leaky exhaust.
be a simple...kinda man. |
That would probably cause more harm than good on a computerized, fuel injected vehicle.
Update, my truck was leaking at two exhaust ports on the passenger side. Repair went well, I heated the head with a torch around the bolts and took all out without breaking any!!!
Manifold was warped, new Dorman manifold, ran a tap to clean the threads, a little copper ultra on a new gasket and new bolts. I also had to replace the down tube, as it fell apart when I removed it from the manifold. To all, Thank you for the help, your input helped me greatly! Bob
Good deal! I figured that was the problem.
