Old 05-14-2018, 09:44 AM
er455 er455 is offline
Default Fuel injection systems
What the best or most common to tune system out there for running fuel injection ?? Anyone running a FAST SYSTEM ? Which one ?
Old 05-14-2018, 01:14 PM
Chris Petersen's Avatar
Chris Petersen Chris Petersen is offline
Send a message via MSN to Chris Petersen
It really depends on a few things...
Who is going to be tuning it, and what options are you after?
Some have traction control, some also have trans control. And number of inputs, and outputs for data logging and such. And if you are going to run batch fire, or sequential, with or without timing control.
I have been running the MegaSquirt stuff for a few years, works good. I built it, wired it, and tuned it myself, but computers are my day job.
Lay out your goals, and if you are not tuning it, find someone you trust to tune it, and ask what they normially use, and go from there.
463 SRP .035 Pistons, Eagle rods, N crank, Pump gas, Victor intake, Holley 850BT carb, 6H heads,TH400 w/T-Break, Continental custom 3500 converter, 3.73 gears. TV7101 TURBO!
