AC resurection
Working on a 77 TA......and the want to resurrect the original AC system...
The compressor was removed years ago... I have most of the hard parts...to install.... What am I checking for on evap and condenser,,and compressor...,other than the obvious cosmetic issues....? What's involved in upgrading to modern refrigerant? Any tips are appreciated... |
New compressor oil, new seals, new hoses and I reccoment a new style sanden compressor with a cycling pressure switch instead of the stock POA valve.
Did you get it working. I am doing this now. Every leak I plug, creates a new leak. I am on my last hose replacement and I might have A/C. Then I want to seal the duct work and by pass heater.
I've back-burnered that project for a while.....doing some maintenance and upgrades on the drivers...
R12 systems used mineral oil, which is a no-no on 134. Use ester oil. Get a new orifice tube for sure. It has a fine mesh screen that could be plugged. This will be at the evap inlet. IIRC, 77's use a thermal cycling probe/switch to cycle the compressor based on evap temp. If this switch still works, then go ahead and use that. If not, then your best bet would be to use a cycling pressure switch calibrated for R-134. These screw onto the accumulator, and should be adjustable. Most people would recommend some sort of hi and low pressure protection switches. The 77 had a switch in the high pressure line going into the evap. I can't remember if it was high or low pressure cutout.
thx!
Oh, yeah... new accumulator for sure.
