Old 06-24-2018, 09:05 AM
hpatton hpatton is offline
Default WTB 1962 425A engine block
Like to purchase a 1962 425A engine block unstamped date code prior to April 1962 Nebraska
Old 06-24-2018, 11:23 AM
61-63 61-63 is offline
I have two 538181 std. bore 2 bolt blocks and a set of 425a 4 bolt main caps and bolts for each. DK date codes but I will look if you are interested. Of course you would have to have the block you bought (if you did) drilled and tapped for the 4 bolt main caps and then have it align bored. $700 for either one with the 4 bolt caps and bolts.
Old 06-25-2018, 03:07 PM
1lms 1lms is offline
I have a standard bore Dec 61 motor but is stamped 08B. If interested PM me. Thanks.
Old 06-25-2018, 08:56 PM
I'll keep your message but I'm really needing a non stamped block thanks
Old 08-18-2018, 08:20 PM
Looking for a 389 425a
Old 08-20-2018, 09:19 AM
ornjcr8 ornjcr8 is offline
The June or July issue of Smoke Signals a person from New York had one for sale . I think the engine was more than your asking for, but you van try.
