Old 07-10-2018, 04:02 PM
musclecarman15 musclecarman15 is offline
Default 1974 spark plug wire seperators
could someone please post a picture of there original spark plug wire seperators...thx keith
Old 07-10-2018, 04:19 PM
Held for Ransom's Avatar
Did your car come with HEI?
So long, farewell.
Old 07-10-2018, 04:30 PM
my is the standard distributor,non hei..thx
Old 07-18-2018, 09:14 AM
74 SD455 Formula 74 SD455 Formula is offline
Did you get your pictures yet.?
Old 07-18-2018, 02:04 PM
no not any yet,thx
Old 07-18-2018, 05:21 PM
unruhjonny's Avatar
off hand, I'm not certain that 1974 had any.
I know that 1975+ used metal brackets which slid into grey wire clamps;
I also know that 1969-1970 use metal brackets with rubber coatings on the ends where the wires were held, but off hand I cannot recall what, if any wire retainers were used between 1971 & 1974.
Most of the engines I was fortunate enough to pick over in the last twenty years or so were 1975-1978 vintage...
very few before that...
But(!) just enough to score a full set and some extra parts for my own car!
Hopefully if nothing else, this will prompt a response with pictures for you
1970 Formula 400
Old 07-18-2018, 10:10 PM
yahooskidoo's Avatar
yahooskidoo yahooskidoo is offline
Default Separators
This is whats on my car Keith.
Old 07-19-2018, 10:04 AM
thank you,thats the picture I need
Old 07-19-2018, 10:23 PM
Looks like I missed replying. But, will add pictures of the early (top one) and later (bottom one) separators.
ID:	488345   Click image for larger version
So long, farewell.
Old 07-20-2018, 10:17 AM
that is exactly why I need pictures,the two styles you show are what I have and needed to know which is correct for my 74 trans am,......so you say early and late can you tell me where the break is,thx keith
Old 07-20-2018, 04:27 PM
I have no idea when the break happened, if it even did happen. It may have been two different suppliers of a similar piece. You would have to get answers from others with '74s (all models) to see if there was a pattern, as the engines were assembled at the engine plant not final assembly. But I would pick the ones with the ears as being correct for your vehicle timeframe.
So long, farewell.
