THE LOBBY A gathering place. Introductions, sports, showin' off your ride, birthday-anniversary-milestone, achievements, family oriented humor. |
I have been looking at these and other brands for quite a while and will pull the trigger before end of August. My must have's are: 10,000 lb. ALI certified, Asymetrical, full height lift (~72inches) and I have 12 ' 4 " ceiling height. A Genuine Rotary manufactured in Indiana is about $5,000 installed .....which is hard to justify for my hobbyist use. I can get a Revolution brand which is Chinese version of Rotary sold by Rotary (thru VSG which is owned by Dover) with the same specs installed for about $3,500 by a local Auto Equipment Dealer. Representative will be in my garage tomorrow taking some measurements and drilling a hole in concrete to determine if I have the minimum thickness that they feel safe to install. If you or someone you know has any experience with Revolution.....please comment. I will ask for local references from the dealer tomorrow.
Can't speak for Revolution, but this is what I was going to buy until I found a deal on a used lift nearby.
http://www.gregsmithequipment.com/2-...d-2-Post-Lifts BTW, Installing a 2 post lift took a buddy & I about 3 hours. If you can read a tape measure, a level, and know how to run a drill, you can install one.
No! Do not try! Do! Or do not. There is no try. - Yoda 1967 Firebird Restoration 2005 - 1/25/2017 ![]() |
thanks for the suggestions Speargun.
I did look at gregsmith in my research. hardest part of install is getting it off the trailer and into the garage!!!! That is why they charge what they do. |
I'm no lift expert, but a cowrker was jussst telling me how he's set on a 4-post lift. And he seems to know his 63 Corvettes.
I'd love to have this one:
https://www.costco.com/Challenger-Li...100302337.html
1970 SSJ: 272 1971 SSJ: 157 1972 SSJ: somewhere between 60 and 350... |
![]() Quote:
Will Rivera '69 Firebird 400/461, 290+ E D-Ports, HR 230/236, 4l80E, 8.5 Rear, 3.55 gears ‘66 Lemans, 455, KRE D-Ports, TH350, 12 bolt 3.90 gears '64 LeMans 400/461, #16 Heads, HR 230/236, TKO600, 9inch Rear, 3.89 gears (Traded) '69 LeMans Vert, 350, #47 heads: Non-running project |
