Old 08-26-2018, 12:05 PM
p4msi1's Avatar
p4msi1 p4msi1 is offline
Send a message via AIM to p4msi1
Default Are Tiger heads too soft for boost?
I have had terrible luck with nitrous and this tiger headed 537. The heads actually started to go concave at the center ports and I resurfaced them 3 times. This time we had to go .010 cut. I was using .060 cometics this last time and pulled 20* timing for only a 200 shot and still torched the block and head. I am selling all the nitrous stuff and putting on my F-2 Procharger, my question is, will these heads work with about 10-15 lbs. boost?
Steve
67 Firebird 3440 lbs, Pump gas 537 IA2, tiger heads, 4.86 rear, 32 x 17.5's, full interior, 4 mufflers, street shape 1.36 60', [email protected] 1/8 mi. 5.67@123 on small shot.
Old 08-26-2018, 12:32 PM
Hooter's Avatar
Hooter Hooter is offline
A guy in our nostalgia group has had a similar experience running NA only. Wonder if a good heat treat on the heads will help fix this issue.
67 Bonneville ragtop
John Langer's Avatar
John Langer John Langer is offline
Steve
It is a cooling problem between the center exhaust valves. Drill some holes, put a second water pump on and you will get 50 hits on the gaskets. That's around how many Rex gets.
Old 08-26-2018, 02:02 PM
chiefbigb chiefbigb is offline
I believe na they are a very good head. With power adders I have heard of some problems. What style combustion chamber are you using?
Be carefull of the feet you step on today.They may be attached to the a$$ you kiss tomorrow.
Old 08-26-2018, 05:24 PM
p4msi1's Avatar
Where should I drill holes???? Should I just sell the heads and get something a little more durable??
Steve
Old 08-26-2018, 07:24 PM
slowbird's Avatar
slowbird slowbird is offline
Steve
I would and if you're going run nitrous get the chambers softened.
Old 08-26-2018, 07:27 PM
p4msi1's Avatar
Nitrous is for sale and i won't be using it anymore. I am putting my Procharger on but before I do, I need to address this issue.
Old 08-26-2018, 07:29 PM
p4msi1's Avatar
After drilling today, I notice that it is completely solid between the 2 center cylinders. I assume you drill completely through, parallel to the stud and exit out on top of the head.
Steve
Old 08-26-2018, 09:58 PM
Scott Roberts Scott Roberts is offline
I ran no water and methanol....normal exhaust temps and torched heads every couple passes... take what you want from that... I know sikgoat gave up on tigers and boost and went to eheads....
Old 08-26-2018, 10:41 PM
7T2 7T2 is offline
Big Chief had same experience
"He who laughs last, laughs loudest"
Old 08-27-2018, 03:49 AM
Dragncar Dragncar is offline
How's your guys experience with boosted engines ?
Old 08-27-2018, 06:12 AM
steve25 steve25 is offline
The heads need a Cryo temper session !
Old 08-27-2018, 06:36 AM
p4msi1's Avatar
So does anybody want to buy a real good set of Tigers?
Old 08-27-2018, 07:29 AM
mgarblik mgarblik is offline
We ran 2 sets of early Tiger heads. Sprayed 600 HP nitrous on these combinations. Our only real issue was the lack of clamp load available on the two step studs that go between the intake ports. Ended up boring those holes for straight 1/2" studs and installing step washers. We used copper gaskets, O-rings, and a wet deck. These heads sealed better than the E-heads for us. FWIW.
Old 08-27-2018, 03:28 PM
p4msi1's Avatar
How many runs did y'all get before gaskets replacement?
Old 08-27-2018, 03:48 PM
RA462's Avatar
RA462 RA462 is offline
Maybe this could be a option for you? I have no personal experience with them.
http://forums.maxperformanceinc.com/...t=tiger+insert
Todd Sedlmeier
Who ever thought pinewood derby cars would lead to this!
October 2004 HPP Shootout participate
http://www.highperformancepontiac.co...out/index.html
86 Grand Prix
535 High Port 8.93 @ 153
65 GTO
433 High Port 12.04 @ 113
Old 08-27-2018, 04:03 PM
Glenn Sedig Glenn Sedig is offline
Default Tiger Deck inserts
[QUOTE=p4msi1;5923779]I have had terrible luck with nitrous and this tiger headed 537. The heads actually started to go concave at the center ports and I resurfaced them 3 times. This time we had to go .010 cut. I was using .060 cometics this last time and pulled 20* timing for only a 200 shot and still torched the block and head. I am selling all the nitrous stuff and putting on my F-2 Procharger, my question is, will these heads work with about 10-15 lbs. boost?
Steve,
I have copper inserts that can be installed to fix your problem. I would like some feed back from some of you that are using them.
We have had good results with the new inserts. We have done 15 to 20 sets of heads and have not heard of any problems other than the ones mentioned below.
I did one set of heads that was running nitrous and went lean. The alum around and under the insert was melted away and almost all of the way thru to the other chamber. The inset looked like it did when it was installed. My customer wondered if the melted area could be welded up without removing the insert. My first thought was no, then I said, it held up to nitrous, maybe it would hold up to welding also. I don't know how or if it was repaired. I would be interested in hearing if the head is fixed and how it was done.
A second set of heads had a problem after several initial dyno pulls. I'm not sure yet what caused the issue, but I will let you know when I find out.
Glenn Sedig
Cell 815 441 0931
Old 08-27-2018, 04:17 PM
p4msi1's Avatar
Yup, considered this option also.
Old 08-27-2018, 04:50 PM
There is no clamping issue. There is no softness issue. There is a heat issue. Remove the heat, remove the problem. It's that simple. Using the insert by itself will not resolve the issue.
Old 08-27-2018, 05:16 PM
We were getting 25-30 runs on a set of copper gaskets. We were running the Flatout coated copper gaskets and the coating would eventually fret through and we would get some water seepage. Occasionally, we would lose the seal between the center cylinders because of the heat concentration with the two exhaust valves. We did not have that modification to the head in the middle that is supposed to cure this. For our match race type deal, this was about half a year for us.
