Has anyone converted a 1969 GTO with a bench seat to bucket seats? Do you have to drill holes or are all floorboards predrilled from the factory?
"The democracy will cease to exist when you take away from those who are willing to work and give to those who would not." Thomas Jefferson 1969 GTO Convertible 1970 Torino GT 429/SCJ 1968 Corvette 427/435hp 1998 Corvette Pace Car 2015 Challenger FF R/T Classic |
You need brackets that are specific to bucket seats....can buy them aftermarket but need to be spot welded to floor pans.
Jimmy M 68 GTO |
The outer brackets are the same with buckets and bench (unless power seats are involved) but as mentioned you need to buy inner floor braces ( used or Repro) that will need to be welded to the floor.
My Break Away Squad 1969 Fbird (base OHC, 350, 400HO & Sprint Cvt’s - 400HO & TA ht’s) 1969 Custom S 2dr ht 1969 LeMans (2dr & 4dr ht & Cvt) 1969 LeMans Safari wagon 1969 GTO (2 Cvt, 2 ht & Judge ht) 1969 Cat (3 Cvt’s & a 2dr ht) 1969 Ventura wagon 2 seat 1969 Exec 4dr post 1969 2 Bonnie Cvt's & 2 wagons 1969 Bonnie Brougham (4dr ht & Cvt) 1969 Grand Prix 2 SJ’s 1969 2+2 2dr ht (Canadian) |
North, bench seats don't use outer brackets, they just mount through the brace on the front bolt just like the back bolt. Buckets put a little perch bracket welded over the top of the hole and plug the threaded insert with sealer underneath it. so he'll need to weld both inner and outer brackets.
The outer rear bolt mounts the same through the floor pan with no add on bracket. |
