Old 09-06-2018, 08:42 PM
67428HO 67428HO is offline
Default 68 A/C POA valve
How do you test a POA valve before installing it? Thanks
67428HO
Old 09-06-2018, 10:43 PM
ponchjoe's Avatar
ponchjoe ponchjoe is offline
Subscribing. I have a couple I'd like to test as well. I found this
https://forums.maxperformanceinc.com...57#post5259657
Old 09-07-2018, 11:17 PM
Ben M.'s Avatar
Ben M. Ben M. is offline
Hook up shop air to the inlet, hook up your gauges to it and see the pressure. The pressure for R12 is like 29-30psi, R134a is like 26psi, which usually corresponds to about 1/2 a turn on the unit.
Old 09-08-2018, 09:49 AM
Thanks guys.
67428HO
