Old 09-17-2018, 11:56 AM
higgenslake higgenslake is offline
Default 225/75/15 fit
Has anyone here installed a 225/75/15 stock wheel,factory ride height with no fender lip modification on a 63?
Old 12-08-2018, 08:08 AM
jim61pest jim61pest is offline
I've had 205-65-15 on my 61, the 2 rears rubbed on fender lip and the 2 fronts hit the upper fender brace when going over a speed bump or driveway
Old 12-08-2018, 10:03 AM
Radman's Avatar
Radman Radman is offline
Probably not. The largest I have fit into a stock 62 was a 215/70R15. They would touch the fender brace while turning into a driveway and hitting the small curb bump there.
If you have done the disk brake conversion to the front, the largest I have found to fit was a 195/70R15. The disk brake moves the tire/rim outboard slightly, that mandates the smaller size.
If you built it, drive it.
red 62 Tempest total stock restoration.
white 62 Tempest modified, 61 389 Tri-Power, and a conventional drive train.
Old 12-09-2018, 03:24 PM
Thank you for the replies.I was asking about a 63.Might be a little different than 61-2.Regardless thanks again.
