Old 09-19-2018, 10:37 PM
goatman73 goatman73 is offline
Default 68 428? ID and whats it worth?
want to make sure this is a 428 that I can buy.its fresh rebuild 030 with prob 1000 miles,one piston somehow has broken ring land,didnt hurt cyl. cast num is 9792968,a178 build date,GME on side of block and wg code on front.has 68 16s on it.dont want to dish out the cash if not 428. thanks for any assistance.
Old 09-19-2018, 11:26 PM
Thats a 1968 428 // 375hp for a manual tranny application.
They had an HO version that was rated 390hp. code WJ
Basic structures are the same on both.
Will have 4 bolt mains too.
#16 Heads are also correct. Big valves with screw-in studs and guideplates.
It won't like pump gas unless you dish the pistons. fwiw
Old 09-20-2018, 11:12 PM
ok thanks, does the GME on the side mean anything?
Old 09-21-2018, 12:13 AM
Not really.
They made a lot of Pontiac engines every year.
All the castings were done in Michigan , all the engines were assembled in Michigan.
They had more than one mold for 428 engine blocks , as well as the other CID's.
One mold wouldn't make enough blocks to anywhere near keep up.
The GME identifies that mold for quality control purposes.
Date Codes and Day/Night Shift markings are another form of ID towards quality control.
They had no idea we would be using these markings decades later to authenticate matching components.
Old 09-21-2018, 09:52 AM
ok thanks for the info.
Old 09-21-2018, 10:35 AM
ponchjoe's Avatar
ponchjoe ponchjoe is offline
Going out on a limb to ask if it had KB hypers in it?
Old 09-22-2018, 11:18 AM
not sure as to the brand of pistons it has it was built by someone who my buddy bought it from.
