Morning all,
Does anyone have a pilot bushing/bearing that will work in a Pontiac 400 so I can use the Tick Plate adapter and my stock mechanical clutch linkage? Its an LS1 T56. Could potentially have a bearing made to go where the torque convertor went I suppose... Please let me know your thoughts, Joel |
The LS T56's have std GM input size of .590". You should be able to order a pilot bushing for any Muncie equipped Pontiac engine. The only issue I can see is if that adapter plate is too thick. It may require a longer pilot bushing (made to Pontiac dimensions) if so. I don't know that is readily available or not if needed,
'67 GTO 400 HO - Ram Air - 4 speed - 3.55 Safe T Track, A/C, PS, red fender liners '78 Lemans - Drag car project |
Ok thank you. I might have found one for an amc hat would work to push the bearing back where it needs to be in relationship to the thicker plate. I am going to order and find out soon enough. It will go into the slot where the torque converter centered up, 1.7” I believe.
https://www.novak-adapt.com/catalog/...shings/amc-gm/ |
![]() Quote:
1968 GTO - 400/400 - Currently being rebuilt - 455/T56 1996 WS6 - LTI M6 - Sold 5/11 1979 Trans Am - 403/Auto - Sold 12/18 |
I did and it seems to be working well. Apologies for the delay in responding. I do not have a lot of miles on it at this point- been working out the pinion angle/driveshaft/vibration related small things now.
Joel |
Which one did you go with? There are two options on that page, and I see there are some kits available as well.
subscribing
Tom V.
