E G T Temps
Went to an aluminum block and have noticed my egt Temps are different by about 100 to 200 degrees different than the iron block . All else is basically the same company timing cam install position ect. Is this normal between the 2 blocked
Hill461 |
Good to know. Solid block correct?
6.98 @ 199mph 4.53 @ 164mph |
Egt
No my block has water in it and I'm asking if this difference is normal from an iron block to an aluminum block
Hill461 |
I sure wouldn't think block material would make any difference in EGT's. Something doesn't seem right there.
Come take a ride http://www.youtube.com/watch?v=P7Y8Awfk2I0 2008, 2013, 2015, 2016, 2019 Central Il Dragway Mod track champion and 2015 IHRA Div 5 Mod champion |
The iron liners in a Aluminum block pass heat much faster into the block / coolant due to being in a Aluminum block, so why would not your Exh temps be lowered by some amount?
The question also is is what's the difference in your water temp, in specific if your running a thermostat how much longer does it take for it to open , as this would be a indicator of faster heat transfer. If all of your EGTs where not lower then that would be a sign of a issue to me! It's time to up the compression to make more heat!
Egt
No thermostat only run an egt thermocouple in 6 and 4 cylinders but they are about even on both sides . I do like the idea of upping the compression I'm at 15 to 1 now
Hill461 |
