In tank electric pump
Anyone here using an In tank electric pump for a carb engine? I went to Tanks web site and they say you can use their pumps for carbs but must use a return style regulator. No problem there but looking for someone with experience doing this with high hp. Looking to upgrade when I get my 535 done as my current fuel system may not supply the needed amount. Looking to feed maybe 900 hp
I had to pull the Fitech off and send it in for a repair early on and decided to drop a carb on in it's place. I just used a RobbMC return style regulator. Pretty simple swap, but I have AN lines for feed & return to the tank.
With as much HP as you're looking at, I would just make sure that your feed & return lines are sized right. I'm guessing AN-10 (1/2") or -12 for the feed. ???
No! Do not try! Do! Or do not. There is no try. - Yoda 1967 Firebird Restoration 2005 - 1/25/2017 |
I have 1/2" hard line front to back. With #10 at the ends for connection. I will have to run a return line and get a return style regulator as I currently am deadheading my Holley HP150 pump. Can I use the Holley regulator? Will it work using the other side to return to the pump. I feed my carb from 1 side of the regulator now.
From the math calculations I am using the HP150 may be enough to supply my new build. ....horespower. X. .6. ÷ 6.1.= GPH of fuel. .... So lets estimate high @950 hp.(very high..lol..) 950 X .6. / 6.1. = 93.44 gph. The HP150 should flow 140gph @ 7psi. I have my regulator set now at 8psi. |
There are a few regulators which come with two springs - one for EFI and a weaker one for carbs.
Make sure you size the return line properly. Some pumps may require a larger return than supply line, in order to drop the pressure low enough for a carb.
'73 T/A (clone). Low budget stock headed 8.3:1 455, 222/242 116lsa .443/.435 cam. FAST Sportsman EFI, 315rwhp/385rwtq on 87 octane. 13.12 @103.2, 1.91 60'. '67 Firebird [sold], ; 11.27 @ 119.61, 7.167 @ 96.07, with UD 280/280 (108LSA/ 109 ICL)solid cam. [1.537, 7.233 @93.61, 11.46 @ 115.4 w/ old UD 288/296 108 hydraulic cam] Feb '05 HPP, home-ported "16" D-ports, dished pistons (pump gas only), 3.42 gears, 275/60 DR's, 750DP, T2, full exhaust |
Yes 1/2" supply and return lines with bypass regulator. Walbro pump, 450 LPH, in tank but I'm only at 570 HP on a quadrajet. They make some larger pumps but at 900HP you might have to run multiple pumps.
One of my Mopar buddies has one in his 500ci street Charger. It took that to help stabilize fuel delivery in the Texas heat with the variability of pump gas volatility. Forgot which one her used.
I'm not sure it will make 900. I'm just estimating high to be safe. Thanks for the reply
I recently came across this guy - http://www.glennsperformance.com/
Much more affordable than other companies. If you don't see it on the website email him. |
I ran the Tanks system in my 600hp 73gto. Used 3/8 steel lines and robbmc regulator. All worked well and pushed the heavy car to low 11s.. ran the car low on fuel while racing and never starved for fuel, so assuming the tank baffle was good!
I plan to run a similar system in my 68 firebird Sent from my SM-G965U using Tapatalk
68 Firebird-- Street/Strip - 400/461 Eagle Forged Bottom End & Ross Flat top pistons. KRE 325 CFM D port, Ultradyne 263/271 @.050, .4267 lift. Crower Solid roller lifters and 1.65 stainless rockers. Quickfuel 1000 on Torker2 intake and 2" open spacer. Hedman 1.75" headers. TH400 w/brake. Ford 9" w/3.80 gears & 28x9 Hoosier pro bracket drag radial. Best ET: 1.35 60ft, 6.29 @ 107.20 mph, 9.99 @132.33 mph. 3,300 race weight |
