700 r4 vs 200 r4
Looking at replacing my tired TH400 with an overdrive transmission. Other than the installation differences (I don't mind changing up drive shaft lentgh and etc.) is there any advantage of one over the other over behind a plus 500 hp - tq 455. Thanks.
Both will need to be upgraded a bit to handle the abuse they may take. It's been my observation looking at both that the costs associated with doing so are pretty similar.
That leaves the gear ratios involved. Behind a large inch, high torque engine, I would lean towards the 200r4 as it's gearset isn't as steep. Another option in the 700r4 however is the 6 pinion planetary which will change the ratios and get rid of that super steep 1st gear. You may also want to make a decision based on what ring and pinion you either currently have or are planning to run. The 200r4 is more suited to lower (higher numerical) gearing while the 700r4 is going to be better with a higher (lower numerical) ring and pinion. You do also have the 4L80E option which is the strongest out of the box and retains the same gearing you have in your current TH400. You do of course have to run a trans control unit with this. To some that's a wall they don't want to scale, but the option is still there.
Here it comes.....
"I know just enough to keep me here, but not enough to get me out" |
The 4L80E is considered the most 'current' upgrade, and is mechanically a better transmission than the other two, all else being equal. That said, I haven't run one in any of my cars personally.
Jeff |
Look at the internals as well as the cost to have one built to handle 500 horse and the choice will be very easy. 700r4 will be the only choice out of the 2. Another good choice (or better) is the 4L80e
Here is my write up... I'm more than a year into it, and it's holding up great. If you want to go 200 4R, look up Art Carr at CPT and either get one of his units or get the internals from him.
http://forums.maxperformanceinc.com/...53#post5758853 Some folks here like to claim that 200s can't handle big torque, in spite of tons of evidence to the contrary.
77 Trans Am, 469 w/ported E-Heads via Kauffman, matched HSD intake, Butler Performance forged rotating assembly, Comp custom hyd roller, Q-jet, Art Carr 200 4R, 3.42s, 3 inch exhaust w/Doug's cutouts, D.U.I. Ignition. 7.40 in the 8th, 11.61@116.07 in the quarter...still tuning. |
My 2004R has been in use for 11 years with my 505 combo that produces over 600 ft.lbs torque from about 4000 up thru 5700 rpm. Peak torque is about 640 ft.lbs. On the last dyno session it made about 660 hp at 5900/6000 rpm. Non lock up Continental torque converter, 3.73 gears and 27.76" dia tires.
EDIT: Not necessarily a recommendation, just a fwiw tid bit .
'70 TA / 505 cid / same engine but revised ( previous best 10.63 at 127.05 ) Old information here: http://www.hotrod.com/articles/0712p...tiac-trans-am/ Sponsor of the world's fastest Pontiac powered Ford Fairmont (engine) 5.14 at 140 mph (1/8 mile) , true 10.5 tire, stock type suspension https://www.youtube.com/watch?v=qDoJnIP3HgE Last edited by Steve C.; 10-17-2018 at 06:17 PM. |
LOL! Like clockwork.
Steve C, where did you get your 2004R?
1970 GTO: Atoll Blue, TH400, 400 +.060, small chamber Ferrea big valve fitted # 15 heads, Summit 2802 cam, Iron intake, Cliff Ruffles 850 cfm qjet, Hooker headers, 2.5 mandrel bent exhaust, Race Pro mufflers, 3.73 Safe-T-Track. |
Thread a few weeks ago on this very subject.
Century Automotive & Transmission in Richmond, Tx.
I wouldn't suggest they or the specific work involved was reasonable in cost. looking back I would offer concerns today. I also changed out the converter they built, way too loose ! .
A detailed analysis 700R4 VS 2004R
I wouldn't run either in stock form. Quote:
A few excerpts from that....
That are truly not worth reading.
Proven by a friend who built his own 2004R from CK's manual and reading hundreds of technical posts from 2004R experts (yup, not everything was in the manual). He did his research and took ownership, the self-built 2004R has lived for years behind his 455. Post 12 above has some accurate information directly relating to the OPs inquiry. Last edited by pastry_chef; 10-17-2018 at 09:44 PM. |
Why? Because they do not sing the praises of the 200 for which there are none? Facts are facts and unless you basically throw all the internals of a 200 in the trash and spend $3500.00+ to make them somewhat last, they will not. You know what they say about a fool and his money don't you? There are tons of much better choices. Hell, even GM abandoned the 200 after a short period of time. Ever wonder why? Warranty claims were just part of the reason.
Apparently Jakes Performance no longer lists the 200R4
http://www.jakesperformance.com/ "....unless you basically throw all the internals of a 200 in the trash and spend $3500.00+ to make them somewhat last, they will not." Good point, my internals got thrown in the trash .
See post 12 for component "praise" from an expert who has actually built more than 30 units living behind power.
My friends 2004R build used similar components to Dave Husek's $2200 "Standard" that is rated for a full weight car to 10.20 E.T. http://www.turbobuickperformance.com...ard-p-114.html He was a crafty fellow and also custom built a deep trans pan from two stock pans. The OP asked about the 700 VS 200. |
PC, that quote from Jake is old, isn't it?
After all the dust settles, you quote the guy that has stopped building 200s, 700s, 4L60Es, and currently has shifted the majority of his business to building 4L80Es. Jake currently doesn't list either transmission in his list of transmissions he builds currently. His current list of transmission products: 4L80E T400 T350 Powerglide Once again, your research is at best poor, because the guy (Jake) has switched his business model primarily to only one OD transmission, the 4L80E. The rest of his offerings are the older direct drive non OD transmissions. I'm sure that someone that has been building all the GM RWD, non OD, and OD transmissions for more than 20 years knows pretty well which of the offerings is strongest. On his site he states that if you want to use one of the light duty transmissions it becomes a wear item. A direct quote from the current Jake's Performance website: Quote:
Also the core supply of 200s is drying up making the business of offering high performance 200s more difficult. Most of shops doing 200s want good cores if they're going to build a transmission for you. If you think your street engine is 550 HP, and in reality it makes 400 HP, you can probably run either transmission forever, especially with street tires. FWIW, my 05 GTO LS2 400 HP/ft lbs torque, 4l60E (700 derivative bone stock from GM Hydramatic division), has 137,000 miles on it since I bought it new, it's just fine, and I expect it will run double that mileage with street tires. In the end if you just wanna spin your tires leaving a car show and then run it through the gears once or twice a week, the light duty transmissions are gonna be fine. Drag racing with 600 honest HP, with slicks is gonna take a toll much quicker. Building a deep sump transmission pan from 2 OEM pans impresses you? I built a deep sump pan from 2, T 400 pans in 1973, it didn't impress me at the time, just a kid with no money that wanted a deep sump trans pan.....
Brad Yost 1973 T/A (SOLD) 2005 GTO 1984 Grand Prix 100% Pontiacs in my driveway!!! What's in your driveway? If you don't take some of the RACETRACK home with you, Ya got cheated Last edited by Sirrotica; 10-17-2018 at 10:56 PM. |
That does not mean a 2004R cannot be built to live in his application!
Today, 01:00 PM 76TA462 76TA462 is offline Senior Member Default 700 r4 vs 200 r4 Default 700 r4 vs 200 r4 Default 700 r4 vs 200 r4 ------------- A 4L80E can handle more? No chit, like a overdrive TH400 |
Chris and a few other 2004R gurus were impressed! LOL More so in skeptics eyes, his home built 2004R is living behind an Ehead 455 that should kill it so quickly. |
