Old 10-19-2018, 05:49 PM
Frank R's Avatar
Frank R Frank R is offline
Default 1968 GTO A/C
) 1969 GTO. Factory equipped with: Air Conditioning, hideaway headlights, Rally Dash, Reclining pass bucket seat, Tinted Glass, Rally II Wheels, Remote Drivers Mirror, Automatic Trans with Floor mounted shifter and Console. Power steering and Power disc brakes.
The restoration is well underway with all the common problem areas being repaired. New full rear quarter panels and outer wheel houses have been installed. The trunk floor and braces have been replaced. The frame is solid and straight and has been painted satin black and installed with new body mounts. New panels have been installed at the base of the windshield and rear window. The floors are solid. New radiator support and bushings and a new fuel line installed. The master cylinder is new.
The engine is a 1969 YD 400 with the correct casting 9790071. I have not heard it run but it spins freely. I'm not sure if the Turbo 400 is numbers matching. The interior is worn and needs a complete interior kit. It also needs brake lines, hood hinges and exhaust'
$ 10,500 or best. This is a land line and I do not receive texts, Phone calls only between 9am-5pm . Located in Watertown, CT. 203-910-3241 [email protected]
ID:	495453   Click image for larger version
ID:	495454   Click image for larger version
ID:	495455   Click image for larger version
ID:	495456   Click image for larger version
Old 10-19-2018, 05:51 PM
Frank R's Avatar
A few more
ID:	495458   Click image for larger version
ID:	495459   Click image for larger version
ID:	495460   Click image for larger version
ID:	495461   Click image for larger version
Old 11-02-2018, 08:30 AM
Frank R's Avatar
Listed on eBay. https://www.ebay.com/itm/1969-Pontiac-GTO-/132838976078
Old 11-07-2018, 10:39 AM
Frank R's Avatar
------------ SOLD -----------------
