Old 11-05-2018, 06:47 PM
dstryr's Avatar
dstryr dstryr is offline
Default ram air flapper housing seal 1969 GTO
What's the reason for the notch in the thin foam strip that goes over the top of the flapper housing? There doesn't seem to be a reason for it. Diagrams show it goes on the passenger side.
Thanks!
dstryr, since 1986
Old 12-30-2022, 10:48 PM
mrennie's Avatar
mrennie mrennie is offline
Resurrecting this thread as I haven't seen any answer to this question. The assembly manual shows the small notch or cutout being installed on the passenger side of the flapper assembly, in line with the actuator cable....but the cable does not pass through the foam seal and where the the seal touches the hood there is nothing protruding that would need the clearance.
Any opinions?
Michael
Oshawa built 1 option Judge basket case. 463, SD KRE 295's, CNC'd factory intake, Cliff's Qjet, Stump Puller HR cam, RARE RA manifolds, Pypes exhaust, T56 Magnum, McLeod RXT clutch, 3.42 12 bolt. 24 year project almost done...
Old 01-18-2023, 08:51 PM
gto4evr gto4evr is offline
well, you asked for opinion here so no facts. I'd say it's a locating point for putting the seal on uniformly so it doesn't hang over one side too far if the installer started too far from the correct spot. if you drop that cutout right at the valley to the inboard side of the scoop it would force the seal to stay centered across them. Once it's squished down into the hood, that gap disappears so it doesn't compromise the seal maybe it was easier than having a notch to line up in the middle and work outward.
Old 01-29-2023, 03:48 PM
3goats's Avatar
3goats 3goats is offline
Thoughts. The slot may have something to do with where the hinged cable bracket bolts to flapper housing? So when flapper closes it doesn't hook onto foam or damage it?
I don't think it comes near that area but it's in line with it, and maybe GM engineers put it there thinking it would come in contact with cable bracket or retainer clamp?
