Old 11-08-2018, 07:34 PM
Chiefkey Chiefkey is offline
Default 1963 Tempest Power Brake Unit
Does anyone out there have an original 63 Power Brake unit on their car ? Found one on the internet.... not sure if it's correct. Photo's of an original setup would be very helpful.
Thanks, JK
Old 11-08-2018, 07:45 PM
tom s tom s is offline
I put one on a 4 cyc car.Dont have any pics now.Send me the link to [email protected] and will let you know if correct.FYI,it has a long stand off that pushes the booster inline with the indent in the drivers inner fender.Tom
Old 11-09-2018, 10:30 AM
c5farmer's Avatar
c5farmer c5farmer is offline
Default brake booster
here are some pictures. The black booster is the correct set up.
ID:	497318   Click image for larger version
ID:	497319   Click image for larger version
ID:	497320   Click image for larger version
Old 11-09-2018, 01:17 PM
elefantrider's Avatar
elefantrider elefantrider is offline
Does it take a special master cylinder or the same as the non-power brake one?
Old 11-09-2018, 01:37 PM
Peter Serio's Avatar
Peter Serio Peter Serio is offline
Make sure you get all the pieces that go to it, there is a long extension rod a clevis, the brake pedal (the hole for the push-rod is drilled in a different spot than a non-power brake pedal). There is also a metal 90 degree support brace that runs off of one of the MC bolt studs over to the Driver's side inner fender well. And the nylon vacuum port which is not 90 degree angled like most all other GM cars; it is straight.
If you don't get all those unique pieces that go to it when you buy the booster those are small items which are probably not going to be easy to find.
Name:	63Lemans Power Brake Setup.JPG
ID:	497352   Click image for larger version
Name:	1963Lemans Power Brake Booster_A.jpg
ID:	497353   Click image for larger version
Name:	1963Lemans Power Brake Booster_C.jpg
ID:	497354   Click image for larger version
Peter Serio
Owner, Precision Pontiac
Last edited by Peter Serio; 11-09-2018 at 01:46 PM. Reason: 63 Lemans Power Vacuum brake booster
Old 11-09-2018, 03:12 PM
c5farmer's Avatar
Default master cylinder
The master cylinder looks the same as the manual brake, BUT without the clevis rod. I don't know if the piston bores are the same or different. The pedal attachement hole is also about 1" lower.
Old 11-24-2018, 11:54 AM
siata siata is offline
I dont have a temest but on the olds f-85 the bore is 1-1/8" I am thinking about using a dual cyl. from a 1989 ford f-150.
This is what the olds has...you think you have issues LOL This is mounted under the dash. I like the tempest set upu better it is more traditional
Old 11-28-2018, 03:51 PM
Default Factory small car power brakes; Buick and Oldsmobile, '62-63.
Many years ago I was going thru some old junkyards and all the way in the back I found an Oldsmobile small body car. I think it was a 62 or a 63 F85/Cutlass. It had a 215 V8 Aluminum engine in it along with factory power brakes. The engine was partially disassembled and some of the top end pieces were gone. but the brake system seemed intact.
I thought some Buick or Olds guy would want the power brake setup. It took several hours to carefully remove all of the pieces that went to it, there was a metal vacuum chamber out underneath the hood, several pipes and hoses. Valves, etc. The pedal and pedal support bracket were unique. The strange thing was the booster was mounted inside of the car, up underneath the dash! Here is the only photo I have left if it. It sold pretty fast as I recall.
Peter Serio
