Garage Sale Any NON-Pontiac related item you want to buy-sell-trade or giveaway!
Old 11-16-2018, 11:37 AM
grahamp grahamp is offline
Default Rear axle
1969 12 bolt posi axle 4.10 gear ratio, just removed from my 1969 Judge because it is incorrect for the car, runs perfectly, brakes and drums included casting number 3959038, date code 0325K, manufactured by McKinnon Industries ( GM Canada ). Located Vero Beach FL. $1700 plus shipping. , Graham. 772 538 7225
Old 11-25-2018, 01:53 AM
Stuckinda60s Stuckinda60s is offline
12 bolt Chevy or Olds? Does it have axle bearing retainers?
Rich
The real democratic American idea is, not that every man shall be on a level with every other man, but that every man shall have liberty to be what God made him, without hindrance.
Henry Ward Beecher
"The problem with socialism is that you eventually run out of other people's money." Margaret Thatcher
Old 11-25-2018, 10:13 AM
Default 12 bolt axle
It is a Chevelle Axle made by McKinnon and originally installed on a Canadian 1969 Buick Skylark. All GM axles of that vintage used C Clips for axle retention. I do not think the axle has been modified to a four bolt retention system. But I will check . The axle is in perfect running condition, just needs to be bolted onto a GM A body frame . I just removed the axle from my 1969 GTO Judge which is a Show Car because the axle is incorrect for the car, Pontiac did not install 12 bolt axles until 1970. Brakes and drums are included with the axle. I will send pictures if you give me your e mail address
