| Performance Parts For Sale/Wanted Just Performance, non-stock, trailers, tools and related accessories here. |
Engine cradle for storage and transportation. Quality made in the USA .
Tig welded and powder coated, grade 5 mounting hardware and heavy duty 3" diameter casters. A unique feature is the 45 degree angle of the bottom " skids " which make it easy to slide the cradle and engine should it be desirable to transport the engine in the back of a pick up or trailer without the wheels. $95 plus shipping. ph. (949) 510 6402 |
BTTT
California?
I have purchased two of these and the quality is hands down the best there is for a Pontiac engine cradle! Here's a picture of my Funny car with its engine mocked up on one of these stands.
James,if someone wanted one for a 265-301 engine could you mod one for it?Tom
Yes Tom. We have the technology. We can build one.
@ Skip Fix …. PM box has space available now.
What part of So. California?
How much for shipping to SC 29693
Tom I had a similar question as yesterday I tried to bolt one up to my 78 block that only has the 3 bolt holes per side. Or a bracket to bolt to the cradle and the upper middle bolt.
Skip Fix 1978 Trans Am original owner 10.99 @ 124 pump gas 455 E heads, NO Bird ever! 1981 Black SE Trans Am stockish 6X 400ci, turbo 301 on a stand 1965 GTO 4 barrel 3 speed project 2004 GTO Pulse Red stock motor computer tune [email protected] 1964 Impala SS 409/470ci 600 HP stroker project 1979 Camaro IAII Edelbrock head 500" 695 HP 10.33@132 3595lbs 1964 Corvette Coupe 327 4 speed |
I think I found and easy solution. The picture of the E head motor above shows the 5 bolt bosses drill. Later motors including 301s use 3 . Here is a picture of the mount and what holes they use. Using a strap that bolts to the cradle where that hole is and tap the strap there to bolt the strap to the cradle and extend the strap to the hole in front of it(3.110") and behind it(3.750") that are near the pan rails so you get more stability than just one hole. If you wanted to pick up that last hole at the very back for a 5 hole block it is 5.150" from the cradle bolt hole.
I have one 557 block with the extra bosses( I think the 78 TA XX block also does) but my 180 HP 78 block only has the 3 needs on the passenger side as shown. and 4 on the other side the 3 used and then the rear most on the driver's side. I think the 301 just has the 3 mount holes but mine is buried and the POS cradle on it covers them.The POS cradle used for a late motor was some other source 20 years ago and it only picked up one bolt and no brace back by the bell housing bolt holes so the pan is sitting on a board at the back! It was made for early motors.
Skip Fix 1978 Trans Am original owner 10.99 @ 124 pump gas 455 E heads, NO Bird ever! 1981 Black SE Trans Am stockish 6X 400ci, turbo 301 on a stand 1965 GTO 4 barrel 3 speed project 2004 GTO Pulse Red stock motor computer tune [email protected] 1964 Impala SS 409/470ci 600 HP stroker project 1979 Camaro IAII Edelbrock head 500" 695 HP 10.33@132 3595lbs 1964 Corvette Coupe 327 4 speed Last edited by Skip Fix; 02-07-2019 at 10:49 PM. |
price and sipping to 08722 please
Do you build these? If so, could one be ordered taller? I want to build a run stand and this would save me a lot of time.
'67 GTO 400 HO - Ram Air - 4 speed - 3.55 Safe T Track, A/C, PS, red fender liners '78 Lemans - Drag car project |
Has anyone heard from the OP been waiting in shipped price?
Thanks |
I heard from him earlier this week. Fedex changed something and he was waiting to hear from them. I am waiting too.
"I know just enough to keep me here, but not enough to get me out" |
Thanks much appreciated
Sturdiest and best casters on any cradle I've had. Pontiac one was so good I bought two Chevy ones.
Do you have a an Olds cradle?
