64-67 Power seat application
I have a 66 Skylark power seat that I want to sell It has no center armrest. I was wondering if an armrest was optional on a Pontiac A body or standard equipment?
I am assuming the power track will bolt in place of non power tracks,so the track could be used on an armrest Pontiac A-body seat no problem. |
my observations from the ones I have dismantled
on the power bench seat 64 65 I think interchange at least the bucket seat is that way.. I aSSume the bench was similar 66-72 interchange bench n bucket seat tracks the mounting brackets to the floor pan change also power and manual ... 64 65 and 66-72 |
A power seat is an A-body was an option for a driver's bucket seat. Not sure about a bench seat but I believe it was an option for it too. Kind of rare if you find an original A-body with a power seat.
A-body 2 door bench seats with center armrests are known as Strato Bench seats. The heavy Strato Bench seats became avail for '67 model A-body's & continued through the '72 A-body models. The A-body power bench seat adjuster mechanism was the same between these years and can occasional be found on 2 door A-body standard bench seats in 233 & 235 series A-body's. Over the years I've pulled more out of Skylarks than any other division A-body
Thanks for the info guys,probably not much call for a 64-66 A-Body bench I guess I will pull the track off and scrap the seat.
what are you looking to get for the tracks switch and wiring
When you really do something right it's like you didn't do anything at all 1931 Pontiac 5 window coupe OHC6 powered 2015 GMC Yukon SLT |
