Old 01-12-2019, 10:47 AM
Cardo's Avatar
Cardo Cardo is offline
Default Black steering column paint
I know, dumb question. Getting ready to paint steering column. It will be black. Which exactly spray paint are you guys using to get the correct gloss level for the column and dash?
"I know just enough to keep me here, but not enough to get me out"
Old 12-17-2021, 05:00 PM
6d7gto 6d7gto is offline
Default Older thread with no replies
I would like to know the same thing!
The Following User Says Thank You to 6d7gto For This Useful Post:
Old 12-17-2021, 09:11 PM
I use gloss black lacquer and polish it until it looks right. Less polishing the more satin it looks. The more polishing the glossier it gets.
Old 12-17-2021, 09:15 PM
mrennie's Avatar
mrennie mrennie is offline
This probably isn't very helpful, but several (many?) years ago I found a quart of Marson Satin Black which is a lacquer than you spray unreduced. Even though is has to be at least 10 years old (if not more), I recently opened the can for the first time and sprayed my column with it and it turned out great.
Of course it is long discontinued. Of interest, I have satin black single stage urethane that I use for other parts and I don't think it would have turned out as well.
ID:	579853   Click image for larger version
Michael
Oshawa built 1 option Judge basket case. 463, SD KRE 295's, CNC'd factory intake, Cliff's Qjet, Stump Puller HR cam, RARE RA manifolds, Pypes exhaust, T56 Magnum, McLeod RXT clutch, 3.42 12 bolt. 24 year project almost done...
Old 12-18-2021, 11:06 AM
gtopont gtopont is offline
Old 12-18-2021, 06:17 PM
So it is much glossier than I thought. My original column must have faded over the years. Does this mean the top of the dash is a different (less) gloss black than the column? What about the lower portion of the metal dash...same as the steering column? Can't imagine they'd be 3 different paints but pretty sure the top of the dash (which could reflect sun into the driver's eyes) was fairly low gloss. If that is the case did the factory mask off this section when painted? I never noticed a line between the top and the sides of the dash when the vinyl dash is removed but guess that could be the case.
Old 12-18-2021, 08:56 PM
1_Wild_Cat's Avatar
There is a difference between the upper and lower dash. The upper is zero gloss with a textured appearance. The lower is low/semi gloss. I can post a photo showing the cut line on a 64 - probably the same for a 65 (?).
Old 12-23-2021, 02:56 PM
geeteeohguy's Avatar
Originally Posted by gtopont View Post
60-40
THIS^^^. Semi gloss or Satin black will be just fine. The original finish was not high gloss at all. Semi gloss.
Jeff
Old 12-23-2021, 04:19 PM
60sstuff's Avatar
60sstuff 60sstuff is offline
Default Original Paint Charts
Magic Mirror colors.
Ditzler colors.
Applications on the flip side of the Ditzler chart.
I disagree with the Gloss application on this chart.
I feel the steering column was always a Semi-gloss in any color. Never a High gloss.
As well as the lower dash, inside belt line sills, etc.
My Original ‘65 steering column which shows a semi-gloss black.
ID:	580478   Click image for larger version
ID:	580479   Click image for larger version
ID:	580480   Click image for larger version
Old 12-23-2021, 04:28 PM
60sstuff's Avatar
Here is a 1964 showing the cut line.
Plus my ‘65 cut line between 0 gloss on top and semi-gloss on bottom of dash.
ID:	580482   Click image for larger version
Old 12-29-2021, 05:18 PM
Chris, I always get a kick when you post up-close-and-personal photos of your unrestored, 57 year old GTO. The car truly appears 'as new' no matter how close you zoom in with the lens. Happy New Year!!!
Jeff
The Following User Says Thank You to geeteeohguy For This Useful Post:
Old 12-29-2021, 09:48 PM
Thanks for the photos and information and thanks to all those who responded. I'm rebuilding my steering column and never realized how complicated they are. There are several columns in 1967 and all are put together differently with different parts. Parts that are not readily available! Good to know the gloss factor now. Fortunately my interior is black. Must be really tough to match the correct paint for those that have other colored interiors.
