Old 01-20-2019, 12:31 AM
Scott Thelander's Avatar
Default open face alternator ID
I have this open faced alternator with NO ID stamping
can some body ID it for me ??
looks like 69 70 71 ?
thanks
do you think its an over the GM counter alternator ?
ID:	503423   Click image for larger version
ID:	503424   Click image for larger version
ID:	503425   Click image for larger version
Old 01-20-2019, 11:13 AM
tom s tom s is offline
Scott,I have a fresh rebuilt one exactly like it?Tom
Old 01-21-2019, 02:42 AM
and the application is ???
Old 01-21-2019, 08:10 AM
On the "no number" open frame 10SI alts, years ago, my previous long time auto electric shop owner noted to me there was a large supply of new Delco 10SI open frame front castings that made it to the rebuilder industry in the '70's. Scott, that's what you are seeing in your example with a common 71+ 10SI rear case. I first ran across "no number" stamped 10SI open frame alternators in the yards in the mid 80's. As I had a complete '70 1/2 TransAm useage YZ 400 in the garage with its open frame "903" alt, the open frame design of the first 10SI alternators iintriqued me & like many other items, knew there would be restoration interest in them. About the same time, I bought my first 71 455 HO Pontiac. Meanwhile, out in the yards every week, began pulling open frame '927 & '928 alt cores, as well as the "no number" 10SI alts, still have quite a few of the "no number" 10SI's. '71 Olds also had a few open frame applications. Note by mid May of '71, Delco quit using the open frame front case in 10SI alt production, why Delco stopped using the "open frame" front case, am not sure.
At home in my shop in the alternator boxes, have a 1100800 which is the first Pontiac application internally regulated alt. The "800" is original to a '68 GrandPrix. The "800" while not an open frame design, does have it own specific design fluted rear case. The '69 usage '832's were open frame design 10SI alts & had a new design fluted rear case, also shared with several Corvette application alts. Very tough to find. More 10SI open frame alts were used in '70, the "70 V8 Firebird versions, as well as several Corvette applications. Of note, the high horse application deep groove pulley 37amp "837's used by Chevy in '69 and '70 were all closed frame externally regulated 10DN's (have had 4 of those over the years) very hard to come by.
Old 01-21-2019, 10:05 AM
68bird400HO's Avatar
To add to this, the no number open frames I have seen are the six spoke variety like the 927s and 928s. The 69-70 open frame alts I have seen on birds, Olds, vettes have a 5 spoke open frame. Also, I have seen aftermarket new chrome alternators also using this 6-spoke open frame.
Old 04-07-2026, 06:53 PM
Originally Posted by 68bird400HO View Post
To add to this, the no number open frames I have seen are the six spoke variety like the 902s and 903s and other 69-70 versions on Olds and Vettes The 71 open frame alts used on our Pontiacs (927s and 928s) have a 5 spoke open frame. Also, I have seen aftermarket new chrome alternators also used this 6-spoke open frame.
Old thread but had to correct the info I posted before.
