Old 01-25-2019, 09:16 AM
Default Line Hone Mandrel for Roller cam bearings
Anyone use Jax Specialty Engines in Hamel MN?
Engine builder Mag had an article on line honing the cam tunnel to insert the roller bearings for the cam.
Very interesting article.
Still some Pontiac Power being built.
Old 01-25-2019, 02:10 PM
Line hone? I’ve align bored blocks for roller bearings but I’ve never align honed one. Pontiacs are one of the few block that utilize the same size bearing on all cam bores, so it seems like a good idea.
Dr. Thomas Sowell
Old 01-25-2019, 02:17 PM
Here's a pic of the article from Engine Builder Mag:
Line Hone Mandrel
May explain it better?
Interesting solution I thought.
Old 01-25-2019, 09:11 PM
Line Hone Mandrel
The only concern I would have is a bell mouthed bore if a machinist was too aggressive in align honing the cam bores.
Dr. Thomas Sowell
Old 01-25-2019, 09:47 PM
I think they had to bore the cam bores out for the bigger roller bearings?
They needed a way to set the boring bar to the bigger diameter?
Old 01-25-2019, 11:15 PM
Bill Meyer's Avatar
Bill Meyer Bill Meyer is offline
Location: West St Paul MN/Mesa,AZ- depending on weather
This is an engine I am working on for Aaronman (member here) Jax is owned/operated by Jack Machula, a very accomplished drag racer from the 60s and 70s. Lyle Haley (Shop Doc) is a very experienced engine builder, shop instructor, author. Both are Pontiac guys, Jack has a '65 GTO that he bought new. Lyle has a '57 Pontiac w/ a 495 ci. - soon to be on the street.
The cam tunnel was way too tight for the bearing (about .004 interference). Lyle came up with the way to use a line hone mandrel on the aluminum block. the bearings have now been pulled in with the BHJ tool. The cam is very happy thanks to Jax.
GT37 3625lbs..Fastest bench seat, column shift, all steel,no power adders car at Norwalk
1.35 w/29.5x10.5x15
6.42 @ 109
10.09 @ 133
Old 01-26-2019, 09:01 AM
Thanks for the info, Bill!
I was wondering whose engine this was.
Forgot Aaron was building an aluminum engine.
Pontiac ingenuity at work!
Old 01-26-2019, 11:27 AM
mgarblik mgarblik is offline
Anyway you could provide a link to the article? I would be interested in reading it. I found Engine Builder Magazine on-line but not the article referenced. Thank you.
Old 01-26-2019, 05:12 PM
Not sure if you have to be a subscriber or not.
Has a link to Month issue, then clicked on it.
Was Jan 2019 I believe.
(just got the paper issue)
I'll try and look for it again.
Old 01-28-2019, 12:17 AM
aaronman aaronman is offline
John - Thanks for posting the article. Bill, Jack and Lyle are a great team. I would never be able to race Pontiacs without their collective knowledge and support. The 535 MR1A block is now being assembled. We'll post some dyno results when it's done. Hoping for around 900hp.
Old 01-29-2019, 02:44 PM
Congrats, Aaron.
Looking forward to it.
Here's a link to the article (I hope it works)
Article Link
Old 01-29-2019, 08:55 PM
Thanks for the link. That was an innovative way to center the mandrel for over sizing. I never really thought about how I would center the mandrel because I don't have one for camshaft tunnels. That's a job I have to send out for now. Only one shop in the area can do them. Interesting solution. That Pontiac engine is lucky to have a shop willing to solve problems and do thongs right rather than just complain it isn't a Chevy or Ford.
Old 02-09-2019, 09:30 PM
leeklm's Avatar
leeklm leeklm is offline
Yep, Bill freshened and balanced my engine at Jax 2 years ago, and did great work!!
68 Firebird-- Street/Strip - 400/461 Eagle Forged Bottom End & Ross Flat top pistons. KRE 325 CFM D port, Ultradyne 263/271 @.050, .4267 lift. Crower Solid roller lifters and 1.65 stainless rockers. Quickfuel 1000 on Torker2 intake and 2" open spacer. Hedman 1.75" headers. TH400 w/brake. Ford 9" w/3.80 gears & 28x9 Hoosier pro bracket drag radial. Best ET: 1.35 60ft, 6.29 @ 107.20 mph, 9.99 @132.33 mph. 3,300 race weight
