I have many HURST shifters, shifter bodies, chrome levers, linkages, linkage parts, knobs, etc., manual and automatic, that I wish to sell. Please let me know what you are looking for and I'll see what I can come up with.
The more specific the request (numbers, description, etc.) the better. |
All who have inquired about shifter parts, please be patient. I will get back to you asap. Thanks.
Im looking for a neutral safety switch for a vintage 70's Hurst Auto Stick
1966 Lemans, 3700Lbs, 406 ci, #96 Heads, Crane 467/494 cam, RPM Intake, Q-Jet, 11 inch Converter, 3:90 gears, 3 inch exhaust, Best ET 12.62@107 MPH 414ci shortblock coming soon! |
I have a couple of those. Will check it out.
I'm looking for a early 1965 Gto shifter handle only. It has a rearward angle that is much more than the later almost upright 1965 handle. It is very similar to a 1964 shifter handle.
Gary |
Gary
I have one 64 shifter (no Hurst stamp) and 2 66's, but none for 65. |
pont406
One had this switch mounted but, not knowing what the actual switch is supposed to look like, I assume this was a do-it-yourself installation. |
Price for 1964 shifter handle ?
1964 GTO shifter. The chrome has been removed from the lever, stamped 2315, revealing stress cracks at the base I'm sure from being heated. The melted plastic receiver bushings confirm this. Otherwise nice needing replating obviously.
The other parts look decent. I will sell with all parts included. $200 shipped. |
Looking for the reverse knuckle the shift rod goes thru to adjust for. 66 gto..you have one?
Sorry, no.
Looking for #2740 stick.
Thanks KC
There isn't a #2740 stick
1964 GTO shifter is sold.
I need complete Competion Plus shifter for 68 GTO. Please let me know. Thanks, Mike
1968 GTO Numbers matching 400 H.O. 4-speed 3:55 1964 T-Bird 46,000 Actual Mile 1928 Model A 2009 Lexus 1981 Dodge D-100 1976 Cadillac Eldorado Convertible 19631/2 Ford Galaxie Fastback |
Just to clarify, are you looking for a factory GTO Hurst or the aftermarket Hurst?
rememberfireball#22, I have a 68 GTO factory HURST shifter available if 433lemans can not help you out. I sent you a PM.
Tim john--- |
I don't have what you need ready for sale at this time.
Do you have a shift boot for a super shifter 3?
www.cqm-inc.com
Skippy, Reach out to the above for custom made bellows (shift boots, clutch fork bellows, brake rod bellows, etc..). They have helped me out in the past with high quality pieces, great price points and fast service. Perhaps they can do the same for you. Tim john--- |
| The Following User Says Thank You to Tim john For This Useful Post: | ||
