Old 02-14-2019, 01:47 PM
3fastgtos 3fastgtos is offline
Default ‘62 Cat pedals needed
Looking for clutch/brake pedals for ‘62 Cat. Anyone know if they’re ‘62 only or do some other years work?
Old 02-18-2019, 09:50 PM
421mike 421mike is offline
Send a message via Yahoo to 421mike
Default pedals
Check with Fabcraft.
Old 02-18-2019, 10:44 PM
tom s tom s is offline
FYI if you find the pedals dont use 62 linkage.Use 63 as it is WAY better.I put 63 in my 62 GP.Tom
Old 02-19-2019, 05:35 PM
marxjunk marxjunk is offline
theres a 63 set up on facebook..i dont know where i saw it, but i thought it as really cheap
Mark..
The Goat whisperer
"I spent a lot of my money on booze, crazy women, and fast cars. The rest I just squandered."
Old 03-26-2019, 05:50 PM
Bump
Old 04-10-2019, 05:31 PM
Still looking
Old 04-11-2019, 10:18 AM
jww jww is offline
Exactly what Tom said. U can use a 61/2 pedal and everything else 63/4.
You’ll be glad you did!
Old 04-11-2019, 10:58 AM
A friend has ‘63 pedals I could get, any idea if they’ll work? I’m planning on using a hydraulic throw out bearing so linkage isn’t my issue.
Old 04-11-2019, 11:22 AM
jww jww is offline
63/4 you could get the standard clutch/brake set up or an H/D pedal assembly used in Borg&Beck pressure plates. The H/D set had a large green spring on the right side of the underdash bracket, however some guys removed the spring.
I believe the 63 pedal may be shaped differently from 61/2 but may work.. not sure, but watch the brake pedal cause there is a difference between P/B and standard brakes. I didn’t know that and struggled for a year trying to get brakes squared away. A 61/2 clutch pedal will bolt right up to your under dash bracket and will work fine. Brad @ Fabcraft in TX sells these and he can get you on the right path with whatever u need.
Hope this is some help.
Old 04-11-2019, 11:40 AM
jww jww is offline
Fabcraft Metalworks on net
I looked at pics 61/2 and 63/4 std clutch pedals look same in pics but not sure. Don’t be scared off by the prices..... he sells everything separately. Good stuff too.!
U can use your current brake pedal, just unbolt the wide P/B pedal pad from thepedal and you have a regular pedal under that
Old 04-11-2019, 02:48 PM
433lemans's Avatar
433lemans 433lemans is online now
Default 61/62 Brake Pedal
I have this nice brake pedal if needed.
Old 04-11-2019, 03:11 PM
That’s some good info there, thank you. I just did what you said and sure enough now I only need a clutch pedal. I’ll call Fabcraft and get a price on just the parts I need.
Thanks for the info guys.
SD
