Old 02-22-2019, 01:12 AM
monzaz's Avatar
monzaz monzaz is offline
Default 10 bolt 8.2 pontiac posi unit and gear set rebuild kit
i HAVE SOME LIMITED QUANTITIES OF YUKON DURA GRIP EATON POSI UNITS FOR DISCOUNTED PRICES
10 BOLT 8.2 YDG POSI -------------365.00 ( 5 UNITS)
10 BOLT 8.2 GEAR SETS YUKON (27 SPLINE PINION)
1 SET OF 3.90 RATIO ---- 220.00
1 SET OF 3.73 RATIO ---- 249.00 NITRO GEAR AND AXLE BRAND
2 SETS OF 3.55 RATIO ---- 243.00
2 SETS OF 3.36 RATIO ---- 283.00
LIMITED QUAntites....
MASTER REBUILD KIT FOR THE PONTIAC 8.2 REAR ----- 109.00 (4 KITS)
HAS THE FOLLOWING ITEMS IN THE KIT.
2 carrier bearings and races
1 inner pinion bearing and race
1 outer pinion bearing and race
1 Pinion seal
1 pinion crush sleeve
1 pinion nut
1 rear inspection cover gasket
1 carrier pack of carrier shims
1 pinion pack of shims
1 marking compound and applicator brush
10 ring gear bolts
1 RED loctite vial
1 booklet to help you with your set-up pattern and torque specs.
NEED ZIP CODE FOR SHIPPING
THANK YOU, JIM
PM WITH INTERESTS AND QUESTIONS
Name:	YUKON posi unit Eaton type 003.jpg
ID:	506300   Click image for larger version
Name:	8.2 gears NEW 001.jpg
ID:	506301   Click image for larger version
Name:	rebuild kit for site 001.jpg
Jim Mitschke
J D Race and Restoration
Richfield, Oh
[email protected]
Old 02-22-2019, 03:06 AM
JKGTO's Avatar
JKGTO JKGTO is offline
What gear ratios and axels will work with the Yukon posi units? Thanks
74 LEMANS GT 350 4SPD MAROON
Old 02-23-2019, 08:42 PM
Gtodoc Gtodoc is offline
PM sent
Sent from my SAMSUNG-SM-G930A using Tapatalk
Old 02-25-2019, 12:40 AM
george kujanski's Avatar
Same question as JKGTO....what ratios will work the posi carrier? I've got 3.23
george
Old 02-25-2019, 01:02 PM
455hota's Avatar
455hota 455hota is offline
To clarify, the stock rear axle in a 1966 GTO would have been a 10 bolt Pontiac 8.2 inch axle correct?
...Steve T.
Pontiacs:
1966 GTO 4 speed Hardtop Alabama car (Marina Turquoise w turquoise interior)
1970 TA 4 speed Canadian car (Lucerne Blue w bright blue interior)
Non Pontiacs:
1966 Lincoln Continental
1967 Ford Thunderbird
1979 Lincoln Continental (Towncar Option)
Old 02-26-2019, 07:53 PM
sprintbird sprintbird is offline
Sent you a PM
Old 02-27-2019, 06:28 AM
fatindian fatindian is offline
Default Posi unit
Will 3:36 gears from a 67 GTO fit this Yukon unit?
Old 02-27-2019, 06:28 PM
monzaz's Avatar
I have listed all the ratio that fit the carrier 3.36 3.55 3.73 3.90 and beyond.
2.93 3.08 3.23 are on the mid series carrier.
2.56 and 2.78 are on the 2 series carrier.
Jim Mitschke
Richfield, Oh
[email protected]
Old 02-27-2019, 06:29 PM
monzaz's Avatar
I am answering the questions in order in the PMs. Sorry it took so long as it has been a busy sporing already.
Jim
Jim Mitschke
Richfield, Oh
[email protected]
Old 03-01-2019, 07:48 PM
Default Posi unit
I'll take a posi unit for my3:36 gears.ship to26301.
Old 03-14-2019, 08:04 PM
monzaz's Avatar
Default You want to buy? Please PM
You have to PM me for the shipping quotes etc. Thank you.
3.90 gears are gone till next order.
Jim Mitschke
Richfield, Oh
[email protected]
Old 03-14-2019, 08:06 PM
monzaz's Avatar
1 set of 3.36 Nitro gears left
1 set of 3.55 gears left
1 set of 3.73 gears left.
end of the month I will shut this down. Just to get you guys off into spring deal.
Jim
J D
Akron, Oh
Jim Mitschke
Richfield, Oh
[email protected]
Old 03-30-2019, 11:48 AM
monzaz's Avatar
0 SET OF 3.90 RATIO ---- 220.00 sold out
1 SETS OF 3.55 RATIO ---- 243.00
1 SETS OF 3.36 RATIO ---- 283.00
1 Pinion seal
1 pinion nut
10 ring gear bolts
1 RED loctite vial
This is it last chance for spring deals--- back to regular price the rest of the summer.
Thanks, Jim
Jim Mitschke
Richfield, Oh
[email protected]
Old 03-30-2019, 01:47 PM
MidnightAuto's Avatar
MidnightAuto MidnightAuto is offline
Just pm’d u. Lmk.
