Old 02-25-2019, 10:26 PM
Scott Thelander's Avatar
Default 1964- 1967 items
1965 GTO front drum backing plates very nice 31000 mile car
brake shoe rub pads show it no wear marks ,, straight ... media blasted .. lite primer.. 150
65 non ac heater control ... real nice from the same car 150
1 cable 25.5" loop to loop 35 works smooth same car
65 2 upper radiator brackets from a lemans and rubbers 35
66 67 rear speaker switch very nice no pitting cut green wires to the radio 75
66 67 drivers door handle outside very nice NO pitting or sander marks 50 1 pit on bottom of thumb button
67 HURST 4 speed handle only real nice original 125
67 convertible 4 speed tranny crossmember sits on the L brackets I think 67 only 175
65 Tempest custom dash plaque ... pretty darn decent its a 7/10 35
65 64/66 ? automatic console shifter top plate and w lens n bulb carrier
both good retaining clips n nice chrome 45 needs paint
65 blinker arm mint no pits or scratches off 31k column 64-66? .. 100
65 front stainless windshield 225 real nice
65 rear window stainless 225 real nice
67 rear drivers side cove stainless trim fair good tab but has a ding 20
4 power window switches 4 bank drivers and 3 singles very nice 250 all
64 power steering pump and brackets really nice tank but busted pulley
this is the later 64 style .. always covered .. 175
67 drum brake spindles and misc 75
67 power steering pump and brackets and pulley non ac really nice straight
reservoir NO pry marks or dents original paint ,,, may have upper alt brackets
nice pressure hose for a survivor car .... always covered .. clean inside also 250
67 non ac 9778886 water pump pulley 40
67 HD cooling 5 blade stationary cooling fan looks like a flex but its solid
with spacer and correct bolts .... came off a 67 400 with A.I.R. and no fan shroud ... it was a weird 67 manual discs 3 speed manual power antenna fm
radio headrest car ....30 years ago 250 never seen another
66-70 dated power steering steering box's 35-250
67 floor shift column a but ruff 75 straight collar...probably needs a blinker switch
67 power bucket seat track real clean working original 650
67 th400 driveshaft real decent 125
67 convert door top stainless trim really nice originals 150 pair
3-67 wire hubcaps 1 nice 2 decent 35 all 3
1965 std rear view mirror and bracket NOT day nite real nice 150
1965 front fender in front of headlight.. splash pans/aprons the little ones perfect originals 100ea or 175 pair
65 muncie shifter mount plate original 40
65 lower door corners 10" square inner outer whole corners from a SUPER dry
drivers door .. media blasted bare ..NO RUST PITTING or issues sweet for that
corner repair with original excellent metal ... 75 pair
67 8 track player untested from big car NO fascia s or surround or knobs 75
67 dual gate ... this was the 67 replacement shifter ... bent HURST handle like the OLDS had but all 67 gto underneath brackets and top plate are all
GTO very very nice period correct .... these were sold in the speed shop and magazine to replace the 2 speed shifter .... 450 ...
post up here first please
then hit me up at
2o6 465 9165 till 1030 pm Pacific
or
Scott68GTO@comcast.net
Scott T
Old 02-26-2019, 12:44 PM
OG68 OG68 is offline
You got mail Scott.
2007 Cadillac SRX
Old 03-02-2019, 10:40 PM
65 upper radiator mount brackets
and
65 slash aprons in front of headlights
have sold on line ...
Scott
Old 03-03-2019, 10:56 AM
60sstuff's Avatar
60sstuff 60sstuff is offline
Hi Scott,
May be interested in 65 standard (painted) inside rear view mirror w/brk.
I’ll call you later today.
Thanks, Chris.
Old 03-06-2019, 02:47 AM
Default update
power steering pump has sold I have others also
drive shaft has sold
ID:	507262   Click image for larger version
ID:	507263   Click image for larger version
ID:	507264   Click image for larger version
ID:	507265   Click image for larger version
Old 03-09-2019, 03:19 PM
turn signal arm has sold
power seat sold for 67 gs skylark wagon build
the mirror is sweet ! exc around the edge ... no fogging ...
the rear shows patina ... thin paint and I wrapped it in a shop towel to not get scratched... has lite rust
2 weird lines in the casting by the mounting screws .. definitely looks to be under the chrome ....
front window trim traded locally
rear window trim double checked and VERY nice
a couple nice front singles available
I will start a new ad after next sale or update
I have a few more items to add ...
Scott
ID:	507520   Click image for larger version
ID:	507521   Click image for larger version
ID:	507522   Click image for larger version
ID:	507523   Click image for larger version
Old 03-04-2023, 09:44 PM
72pontiac's Avatar
72pontiac 72pontiac is offline
whatever came of the drum brake backing plates ?
Old 04-28-2023, 10:03 PM
Bump
