Old 03-13-2019, 11:28 PM
1oldgoat's Avatar
1oldgoat 1oldgoat is offline
Default NOS Parts List 3
All parts are NOS unless indicated otherwise. Thanks for looking!
Description, Part Number, Application, Price
Alternator pulley 1949355 65-68 T8,T6,P8 w/PS & AC $50
Vac cont switch, TCS. 1997419 73 all V8 w/man trans $250
Water pump pulley 9796062 69 all w/AC $25 (used)
Tail light lens, LH 5959879 68 Tempest Custom $125
Headlight knob 488357 73-75 A,B,G $35
Disc brake piston 5463483 69-73 all w/disc brakes $35
Disc brake piston set 5457251 67-68 w/4 piston disc brakes. $125
Fuel gauge 6430890 All 68 A exc safeguard $85
Headlight switch 1995170 68 A w/o vac op $55
Turn sig cancel cam 9787615 67 all exc w/tilt $25
Turn sig cancel cam kit 7812210 69-75 all $25
Headlamp adj spring 480773 71-72 A,G,B 73-74 G 74 F,B $5 8 avail.
Thermo switch 6490546 73 all V8 $75
Vac spk thermo switch 494510 73 all V8 $50
Radiator supp insulato. 478779 70-73=all exc X, 74-76 A,B,F, 74 G $25
Hrn Btn sw w/dlx wheel 481985 69-70 all $35
Axle seal 9799291 69 F, 70-72 A,G $30/pair
Master cyl repair kit 5468331 67 P8,T6,T8, 68-69 all moraine exc DB, $45
71-72 A exc DB
SeeLite, fiber optic cable 6293975 68-72 A,F, 73-74 A,G w/AC, 73 F $15
Neutral safety switch 3983966 70-78 F $125
DB piston ret spring set 5469180 69 DB $15
Spd cont spk sw. 35-39T 546629 72 all w/M40 $125
Spd cont spk sw. 40-45T 546630 72 all w/M40 $125
Diff cover gasket. 9775683 64-72 A,F,G w/10 bolt $12 8 avail.
Intake gasket 485950 72 455 HO, 73-74 455 SD $200/pair
Intake gasket 9785763 65-71 all D-port V8 $35/pair
Throttle cable 9792710 71 All B w/4BC $85
Battery tray 9790365 68-72 all A w/6cyl. $85
Fuel pump 6550 5621875 64-65 T8, 63-65 P8 $225
Fuel pump 40508 6416834 66 T6 w/4BC $95
Fuel pump 40521 1st des. 6416911 67 T8 $150
Fuel pump 40610 2nd des. 6417175 67 T8 $150 2 avail.
Fuel pump 50528 6416912 67-69 F6 w/4BC, 67-69 T6 w/4BC $150
Fuel pump 40710 6470222 70 T8, G8, B 455 w/MT or HP $185
PM me if you have any questions. All prices are plus shipping.
ID:	507919   Click image for larger version
ID:	507929   Click image for larger version
ID:	507931   Click image for larger version
ID:	507932   Click image for larger version
68 GTO Ram Air I Auto, Starlight Black/Teal-Survivor
68 Firebird Ram Air II 4spd, Aegena Blue/Black/Black
68 Firebird 400 Conv. Auto, Red/Parchment/Parchment
69 Firebird Ram Air IV, 4spd Matador Red/Black-Survivor
70 GTO Ram Air III 4spd Conv. burgundy(currently Black)/White/Black
71 GTO 455HO 4spd, Lucerne Blue/Black/Black
71 GTO 455HO Auto, Lucerne Blue/Sandalwood/Blue
Old 03-13-2019, 11:33 PM
1oldgoat's Avatar
More pictures 1
ID:	507934   Click image for larger version
ID:	507935   Click image for larger version
ID:	507936   Click image for larger version
ID:	507937   Click image for larger version
Old 03-13-2019, 11:39 PM
1oldgoat's Avatar
More pictures 2
ID:	507939   Click image for larger version
ID:	507940   Click image for larger version
ID:	507941   Click image for larger version
ID:	507942   Click image for larger version
Old 03-13-2019, 11:44 PM
1oldgoat's Avatar
More pictures 3
ID:	507944   Click image for larger version
ID:	507945   Click image for larger version
ID:	507946   Click image for larger version
ID:	507947   Click image for larger version
Old 03-13-2019, 11:47 PM
1oldgoat's Avatar
More pictures 4
ID:	507949   Click image for larger version
ID:	507950   Click image for larger version
ID:	507951   Click image for larger version
ID:	507952   Click image for larger version
Old 03-13-2019, 11:52 PM
1oldgoat's Avatar
More pictures 5
ID:	507954   Click image for larger version
ID:	507955   Click image for larger version
ID:	507956   Click image for larger version
ID:	507957   Click image for larger version
Old 03-13-2019, 11:57 PM
1oldgoat's Avatar
More pictures 6
ID:	507959   Click image for larger version
Old 03-14-2019, 12:10 AM
Uncle Judge's Avatar
Uncle Judge Uncle Judge is offline
Hi Scott, I will take the Radiator supp insulato. 478779 70-73=all exc X, 74-76 A,B,F, 74 G $25
Thanks, Jeff
Old 03-14-2019, 12:31 AM
60sstuff's Avatar
60sstuff 60sstuff is offline
Default Interested
NOS 6550 fuel pump.
Do you have a pic of the date code, the bottom cover and side ports.
Thank you, Chris.
Old 03-14-2019, 12:48 AM
1oldgoat's Avatar
Originally Posted by 60sstuff View Post
NOS 6550 fuel pump.
Thank you, Chris.
Does this help?
ID:	507981   Click image for larger version
ID:	507982   Click image for larger version
ID:	507983   Click image for larger version
ID:	507985   Click image for larger version
Old 03-14-2019, 01:04 AM
60sstuff's Avatar
Thank you for the additional photos.
I will PM you.
Chris.
Old 03-14-2019, 09:47 AM
60sstuff's Avatar
Scott,
I’ll take the 6550 fuel pump - SOLD!
Thanks, Chris.
PM me with payment process.
Old 03-14-2019, 03:38 PM
64-3Deuces's Avatar
64-3Deuces 64-3Deuces is offline
PM sent
Old 03-15-2019, 04:11 PM
gtospieg gtospieg is offline
PM sent.
Old 03-15-2019, 07:24 PM
1oldgoat's Avatar
The following parts are sold.
Thanks guys!
Old 03-15-2019, 08:08 PM
mkgto1970 mkgto1970 is offline
PM Sent
Old 03-16-2019, 09:16 PM
6d7gto 6d7gto is offline
If not sold, would like the master cylinder repair kit 5468331.
Old 03-16-2019, 10:08 PM
1oldgoat's Avatar
It’s yours. I’ll PM you with payment information. Thanks!
Old 07-27-2020, 04:12 PM
A Rare 70 A Rare 70 is offline
I know that this is an older thread, but is the 40710 (6470222) fuel pump still available by chance? I sent you a pm last week but have not seen a response. Thanks!
Old 07-27-2020, 04:24 PM
1oldgoat's Avatar
Sorry, I did not receive a PM. I believe the 40710 pump is sold but I will check this evening when I get home and let you know. Thanks.
