Old 04-08-2019, 01:49 PM
DM3 DM3 is offline
Default 1st Gen Halo Headlights
Has any one installed halo headlights on a first gen? If so, where did you get them?
I saw a chevelle the other day with them but could not turn around and flag him down.
DM3
Follow my rebuilds:
IG: #67MoparBird
https://www.youtube.com/@Nasty_Muscle_Cars
https://www.tiktok.com/@nasty_muscle_cars
1967 Firebird 400
1969 Toyota FJ40 w/ SBC 350
Appeared on Gearz, Season 16, Episode 1,
Segment 'What Are You Working On?'
Old 04-08-2019, 06:37 PM
hojs69's Avatar
hojs69 hojs69 is offline
Location: Pacific NW by way of Detroit, Tampa, San Diego
Options here.
https://www.ecklers.com/shop/pontiac...lectrical.html
I've switched all lighting to LEDs. Heads, tails (Dakota) and markers. Win/win - brighter and less current draw. Also, wanted to preserve as much electrical energy for other parts even with a MegaAmp (tradename) alternator; ex. water pump, fans, fuels pumps, etc....
79 Trans Am WS6
71 Formula
72 Formula
71 Firebird
69 Firebird
Old 04-08-2019, 07:46 PM
Tim john Tim john is offline
AMES offers the Halo headlights for our first gen Firebirds in their catalog.
Tim john---
Old 04-09-2019, 09:38 AM
JLMounce JLMounce is offline
The higher quality stuff is typically from DapperLighting or JW Speaker. Here's the halo variants from Dapper in the 5.75" fitment we need.
https://www.dapperlighting.com/colle...s/products/575
I'm actually waiting for them to drop the OE glass 5.75" offering. It doesn't have the halo you're after, but it looks stock with a modern LED Projector. One of the things about my car I despise is driving it at night with the crappy sealed beam halogen lights after getting out of one of my modern vehicles.
-Jason
1969 Pontiac Firebird
Old 04-10-2019, 10:26 AM
RocktimusPryme's Avatar
I feel the same. Ive been considering one of the conversion housings that uses an H4 bulb. I know a lot of guys say they hate bright bulbs in a classic car, but man it just seems dim after driving my truck. Im not super familiar with all the terms but I think that type of conversion housing allows you to use a Zenon bulb, which should be brighter.
I do want lenses that look at least close to factory though. Im not interested in the halo.
Old 04-10-2019, 10:40 AM
This is the only offering they have currently with the OE glass, for 7" housing lights.
https://www.dapperlighting.com/products/oe7
They claim the 5.75" offering should drop some time this summer, but you know how that whole deal goes sometimes.
The lights look like the sealed beam halogens, but have projector LED's in them.
-Jason
Old 04-10-2019, 10:50 AM
https://www.summitracing.com/parts/h...0811/overview/
I was looking at these. You can find conversions cheaper, but those have good reviews, and Hella actually has their own website so you can probably get a hold of them with issues. Plus Summit usually has good support.
And the lenses look close enough, no crazy European cues.
Old 04-10-2019, 12:06 PM
firebird69racer's Avatar
firebird69racer firebird69racer is offline
I have seen good reviews and a couple of friends have used these guys
http://haloheadlights.co/
Old 04-10-2019, 12:08 PM
Inogame Inogame is offline
I used these, marketed for Chevelles but are white LED halo with original style glass.
http://www.chevelle.com/1964-1970-Ha...hts-P7969.aspx
Install was simple and when the Halo is not on you cannot tell they are anything but stock.
This link was the article where I found out about the headlights -
http://www.superchevy.com/how-to/pai...ssic-chevelle/
I don't have a great pic of them on, but I attached the best one I could find here at the office. They look really nice even if my pic is terrible.
Old 04-10-2019, 02:02 PM
Totally ignorant question but how does the halo effect work? Is it a separate switch? Or is it haloed when you turn the lights on.
Old 04-10-2019, 02:33 PM
I have them tied into the running lights so they come on when I pull the headlight switch back halfway.
There is a separate wire in each bulb for the halo, you could tie it to a switch if you wanted. they are LEDs so very little volt/amp pull.
I'm not an electrical wizard, but I feel like there would be many options depending on what you wanted to do.
The regular bulbs work no different than the normal light harness, same connections as stock.
Old 04-10-2019, 02:38 PM
Oh okay, so they are only cosmetic, don't add any light to night drivability. If you don't want to hook them up just don't provide power to that separate wire.
Old 04-10-2019, 03:49 PM
92GTA's Avatar
92GTA 92GTA is offline
I went with these a couple years ago:
https://www.ebay.com/itm/5-3-4-Headl...-/122129975330
No halo mind you. I don't want to look like a Challenger lol.
Old 04-11-2019, 01:26 PM
DM3 DM3 is offline
Great info guys, thanks.
Will be rebuilding front end soon and need to decide the direction I am going.
Follow my rebuilds:
IG: #67MoparBird
1967 Firebird 400
Old 04-11-2019, 08:17 PM
1stGenFB 1stGenFB is offline
I did an HID retrofit for low beam. Using H4 halogen for high beam
Name:	2019-03-16 19.07.23 black out.jpg
Old 04-13-2019, 10:13 PM
LeighP's Avatar
LeighP LeighP is offline
J W Speaker make halo 5.75" LED projector lamps with either a white or amber halo......great lights, I have the 7" versions on my Jeep Wrangler.
The downsdie is they require a special mount pad (available from JW Speaker) as they don't fit conventional light buckets.
Regards,
Leigh
Pontiacs I’ve owned….
1960 Laurentian 283
1963 Laurentian 283
1976 Trans Am 400
1977 Trans Am 400
1951 Chieftain Flat head 6
1967 Firebird 400 convertible
1967 Firebird 400 coupe
1979 Trans Am 403
1971 Formula 455 (clone)
1969 Firebird 350
1968 Firebird 428 manual.
Sydney, Australia
Old 05-01-2019, 08:35 AM
67 455 Bird ragtop's Avatar
67 455 Bird ragtop 67 455 Bird ragtop is offline
Actually halos can work as DRLs like on most new cars. I plan on using switchback halos on my 67. These also act as amber turn signals. I'll use the high beam bulbs for this. If you see a new challenger or charger they use this type of setup. I'll wire the factory signals to be on when I turn on the headlights.
67 Firebird Convert 455 +.060 TH400 74cc KRE d-ports piston dished 16cc H-beam rods Comp Cam 305-AH-8 cam 108* LSA 253/260 @.050 duration .577/.594 lift w/1.65 rockers Ford 9" 3.50 Detroit Locker M/T Sportsman Radials 31x18x15 on Convo Pro 15x15s
Old 05-18-2019, 09:43 AM
DM3 DM3 is offline
I am leaning towards the Dapper Lighting 575 kit with amber halo and LED with smoke protection covers.
If anyone has the Dapper lights installed, can you post some pics?
DM3
Follow my rebuilds:
IG: #67MoparBird
1967 Firebird 400
