Old 04-11-2019, 05:32 AM
Txbobcat Txbobcat is offline
Default problem with 428 install in 65 catalina
Got the 428 together and installing it in the 65 catalina. First the harmonic balancer is sitting on the sway bar
. I lower the sway bar then notice that the oil pan is sitting on the engine cradle. Mounts are hooked up but somehow I need to move that engine up about 1/2 inch to get it off the frame.
I have new motor mounts and the book says 65 thru 70 and the engine is a 69 so I thought all would be good. Oil pan is original to the 428. 65 oil pan seems to be bigger so what is the problem?.
At this point I am thinking about removing the motor mount frame piece and welding it 1/2 inch higher so it can clear the cradle and also moving the tranny up as well.
Before I do this wondering if anyone else has experienced this problem with the same car and engine.. Any suggestions would be appreciated.
Old 04-11-2019, 09:52 AM
AROWHED's Avatar
AROWHED AROWHED is offline
Send a message via Yahoo to AROWHED
Ran into this on my 65 GP with a 71 455 years ago. The 71 harmonic dampener is larger than a 65 dampener. I used 1/4" steel plates to shim between frame and bar mounts, slightly lowering bar. Or better yet, change to an Addco bar, which has a clearance bend, and is much better than stock for handling.
As for oil pan, try gently raising engine and add shims between mount and frame first. You may have to die grind the slot in the frame mount a little, for bolt clearance, as the engine moves up.
Red\black 65 Grand Prix 467 E-head stroker, Viper T-56 6-speed, 4.10 spool
Old 04-11-2019, 10:01 AM
77 TRASHCAN's Avatar
Has anything changed on how the trans sits on the cross member???
Shut it off
Shut it off
Old 04-12-2019, 05:50 AM
I shimmed up under the motor mounts and fixed the problem
Old 04-12-2019, 07:20 PM
stevep's Avatar
stevep stevep is online now
Is it a problem?
Old 04-16-2019, 10:59 AM
389 389 is offline
Is the closed chamber 389/421 that bad? Those closed chamber heads love wide lobe separation cams...
Old 04-17-2019, 07:22 AM
Had to quit for a few days. Tranny mount was broke ordered a new one. Have to go to work in Mo for a week or so. Will report back
Old 05-12-2019, 10:46 AM
MPKind's Avatar
MPKind MPKind is online now
Use year correct parts for the oil pan, balancer and mounts. It will solve all the clearance issues. Addco bar works great with a stock setup.
Aftermarket pans all rub on the drag link. I welded a baffle in mine to keep the oil down, bought a new performance balancer from Tin Indian or Butler. Original 2 piece style. Never use a 50 year old balancer. The block doesn’t matter from 65 and up. all dimensionally the same on the outside.
The point is that the all these cars were fit with specific bolt on parts to fit a specific year and model beyond the long block. No trial and error or welding required.
