1970 GTO/JUDGE PARTS
1970 NOS FRONT WINDSHIELD UPPER STAINLESS MOLDING $175.00
1970 NOS PASSENGER SIDE FRONT WINDSHIELD STAINLESS MOLDING $90.00 1970 AM &FM RADIO PULLED OUT IN 1983 WORKS $475.00 1970 AM RADIO WORKS $200.00 1970 GTO FRONT BUMPER PREP OFF CAR 30 YEARS $1400.00 1970 QUADRAJET CARB PULLED OFF RUNNING CAR #7040263 $375.00 1970 JUDGE FRONT BUMPER GRILLS ALL TABS IN PLACE $475.00 1970 JUDGE GRILLS $300.00 for pair $150.00 singles 1970 GTO FRONT BUMPER TO FRAME BRACKETS $350.00 1970 GTO FRONT HEADLIGHT HOUSING ASSEMBLIES $250.00 11 Bolt Timing Cover $110.00 11 Bolt Timing Cover withy divider plate and pump $150.00 NOS 1970 Wheel well moldings $850.00 1970 pair of used rear wheel molding $200.00 1970 power brake booster $50.00 1970 lower main duct and vents $125.00 1970 Intermediate steering shafts $50.00 1970 Rear Windshields $80.00 1970 Coils $25.00 1970 Oil Filter housings $85.00 each 1970 front lower window reveal molding $60.00 1970 rear front upper fender chrome moldings $30.00 pr. 1970 Throttle cable $45.00 1970 Turbo 400 Transmission oil pans $50.00 1970 door vents pr. $20.00 1970 positive battery to starter heat shield tube, 1970 window regulators set of 4 $150.00 1970 brake pedal assembly $100.00 1970 emergency brake pedal and bracket $75.00 1970 rear license plate bracket and holder 1970 water thermostat housings $20.00 1970 door hinges $50.00 1968-72 points distributors $80.00 1970 wiper transmission assembly (2) $75.00 1970 blower motors $25.00 1970 a/c inner boxes $150.00, 1970 headliner bows $50.00 set 1970 Power Front Disk Master Cylinder $45.00 1970 Harmonic balancer $50.00 1970 Full length windage trays $85.00 1970 Show Quality Front Window Stainless Moldings, Professionally Polished $300.00 NOS A/C Delco PVC $9.00, NOS PULLEY 481040 still in GM BOX $100.00 NOS A/C Delco oil Filters PF 24 $11.00 each NOS Three prong Thermo Switch for rally gauges $250.00, 1971 GTO Rear Taillight lenses $150.00 Each 1970 Rear Taillight housings $75.00 Each 1969-72 Goldenrod/Tan & Pewter/Gray PEWTER steering wheels crack free $125.00 1969-72 auto shifters $135.00 Fuel escentrics $35.00 1970 harmonic balancer $50.00, flexplates $35.00 1970 inside glove box liner $45.00 1970 Standard Gauge & Speedometer cluster $65.00 1970 GTO/LEMANS Rear window Defroster Switch with wiring harness $150.00 assorted stainless moldings, 1970 driver side lower black dash metal trim $50.00 1970 radio rear support bracket $25.00 1970 Tag light & bracket $15.00 Distributors 1148 Feb13,70, 1253 Jun 26,68, 2007 Nov 28,69, 2189 Apr 24,72, 2513 Nov 15,73 all distributors $80.00 1970 door glass $100.00 used pulleys 481040XT water pump pulley, 481038YB crank pulley, 480507 crank pulley, 8inch 2 grove water pump pulley, 480509 1970 pillar post covers $45.00 new points and condensers __________________ Timmy Mallory Email me at temallory@msn.com
Timmy Mallory |
radio
I would like more info on the 2 radios. can you send pictures? thanks
grills
can you also send pictures on the grills and carb?
pm sent
Timmy Mallory |
Looking for P# 8702432
I sent you a PM. Thanks, Marc.
bluejudge I did not receive pm. email me at temallory@msn.com
Timmy Mallory |
Thanks, I sent you an email. Thanks, Marc.
