Old 05-04-2019, 07:55 AM
jimib's Avatar
jimib jimib is offline
Default Alternator Belt, looking for correct fit
I've shopped locally for an alternator belt but the belts I've bought are either too long or too short. The alternator brackets are original.
I see one in the OPGI magazine for $53.00. This seems like crazy money for a belt when locally I've spent $12.00. Any suggestions such such as a part number through Summit Racing or Napa or common auto supply chains through out the states?
67 GTO, Auto, PS, no AC
1967 GTO, hard top, 400 Block, Butler Performance Build, EFI Holley Sniper, Tremec 5-Speed, Moser 373 Rear, 4 Wheel Disc Brakes
Old 05-04-2019, 08:08 AM
jimib's Avatar
I'm also looking at the National Parts Deport magazine and they are showing 4 belts listed as 1st, 2nd, 3rd and 4th qtr. I called them for support and they sound as clueless as I am.
Old 05-04-2019, 10:02 AM
Old Goat 67's Avatar
Be advised that there are different width belts used.
Parts people do not know this anymore. That's what causes the screech.
Mine is an AC car, NAPA Premium XL #25-7495 on alternator, NAPA Premium XL #25-13453/7530 on PS.
Old 05-04-2019, 11:09 AM
242177P's Avatar
242177P 242177P is offline
Belt width is real important, but IMO nothing promotes belt slippage like a shiny groove. In that respect, that chrome pulley isn't doing you any favors. IIRC, 66s didn't use the wider belt, so should one get added to the mix...
Old 05-04-2019, 05:05 PM
jimib's Avatar
The part #25-7495 you mention; does this belt also wrap around the AC unit?
Old 05-04-2019, 05:40 PM
No, that's a third belt.
Old 05-04-2019, 08:34 PM
fyrffytr1's Avatar
Gates #7495 for fan and Alternator, # 7512 for fan and power steering.
Old 05-07-2019, 06:16 PM
jimib's Avatar
I picked up part #25-7495 from Napa today; it's clearly too long., I have a Butler Performance built engine, maybe they put on a smaller pulley on the crank. Anyway, back to the auto parts store tomorrow
Old 05-07-2019, 07:47 PM
Scott Thelander's Avatar
something I see is ..
thats not a factory tin alternator pulley.. in your picture
looks like a solid repro or a buick one ..
its diameter is probably different than original also making the correct belt not fit
along with the other pulley diameter differences you mention may have happened ...
are your crank and water pump pulleys tin or aluminum ??
pictures ?? part numbers ??
Old 05-08-2019, 05:19 PM
jimib's Avatar
Finally, Napa XL 25-7475 seems to be a great fit.
As for belt tension; should I pull the alternator back with one hand and tighten the bolt with the other or should I use a pry bar to make it really tight?
Old 05-08-2019, 05:49 PM
242177P's Avatar
Hard to say just how tight it needs to be. Too tight is hard on alternators. Too loose causes slippage. Look at the longest straight section of belt, at about the midpoint and see how much slack there is. I'm guessing an inch of flex (total) should be close?
Old 05-09-2019, 10:47 PM
Mister Pontiac's Avatar
Mister Pontiac Mister Pontiac is offline
Agreed. Hand tight will almost certainly cause it to squeal with any kind of electrical load draw or RPM. Too much pulling with a pry bar is too hard on the alternator bearings.
The sweet spot lies in-between.
Eric Mitten
'74 Bonneville 4dr Sedan (455/TH400/2.93 open)
'72 LeMans GT (455/M-13/3.23 [8.5"] posi)
'71 GTO Hardtop (400/TH400/3.07 12 bolt posi)
‘71 GTO Convertible (455HO/TH400/3.23 posi)
'67 GTO Coupe (455/ST-10/2.93 posi)
Deuteronomy 8:3
Old 05-10-2019, 03:31 AM
92GTA's Avatar
92GTA 92GTA is offline
In the middle of the belt, you should be able to give it a 1/4 twist (turning the bottom sideways) with your hand. No more, no less, that should be perfect.
1969 Pontiac Firebird
Old 05-11-2019, 09:33 PM
GT182's Avatar
GT182 GT182 is offline
I was always told to have 1/2" of play in the belt. 1" is too tight, and tightened by hand is too loose. And that was by professional mechanics back in the 60s. Back then they knew how to do things the right way.
Gary
Get in, ShuT Up, Hang On!
"Crusin' Is Not A Crime"
Keep yer stick on the ice.
