Old 05-06-2019, 10:37 PM
konwal455gto konwal455gto is offline
Default D port header gasket
Who makes the best d port header gasket for 65 389 ? Thanks Bill
Old 05-06-2019, 10:58 PM
tom s tom s is offline
Reflex.Tom
Old 05-06-2019, 10:59 PM
Reflex,sorry
Old 05-06-2019, 11:00 PM
Hate spell check!Remflex
Old 05-07-2019, 05:30 AM
JSchmitz's Avatar
JSchmitz JSchmitz is offline
X2 on both points!
Old 05-07-2019, 05:41 AM
steve25 steve25 is offline
To help ease there install hang the Headers on all the bolts first ,then cut the gaskets into 3 sections ( each end port and the middle ) then notch / cut each bolt hole from the bottom of each bolt hole and then slide them in place while rocking the header.
This method also helps the gasket to not tare as the weight of the Exh system hanging off of them makes the Header shift in shape some over time.
Be sure to use antiseize on all the bolts and to check all the bolts for tightness after the first 3 heat up and cool down sessions.
Old 05-07-2019, 10:50 AM
If using the Remflex,be VERY careful trying to cut them.They are the best I have found but if bent can crack and end up in the trash.Tom
Old 05-07-2019, 05:46 PM
JSchmitz's Avatar
Very true. Quite brittle. I use a razor utility knife.
Old 05-07-2019, 06:50 PM
Default best headed gasket
Thanks for all the replies ! would like to do this for the last time Bill
