Old 05-13-2019, 04:20 AM
Tommo99 Tommo99 is offline
Default 2500 stall converter for my 59
Anyone know where I can buy a new torque converter with a 2500 stall for my 59?
Old 05-13-2019, 11:37 PM
Origin trans? Which one? One doesn't have a TC it has a fluid coupling.
Old 05-14-2019, 01:45 AM
Jack Gifford's Avatar
formerly 'Pontiac Jack'
I'm not aware of anybody ever doing that- it would be up to you to experiment with brazing and cutting the main-torus fins. The design of the Dual Coupling HydraMatic rules out converting one to racing. The 1-2 and 3-4 upshifts require filling the smaller fluid coupling- which cannot happen in a tenth of a second- the typical actuation/release time of bands and clutches (as in Dual Range HydraMatics).
Or- do you perhaps have a Canadian Pontiac with a Chevy engine? If so, ignore what I said above.
Old 05-15-2019, 12:14 AM
Thanks yep its the original 59 4 speed automatic, i think your correct as it doesnt look like a normal torque converter, i will check the manual tonight i have an original workshop manual for it.
Old 05-15-2019, 12:15 AM
yes original trans and i think its a fluid coupling like you said
Old 05-16-2019, 11:52 AM
60man's Avatar
60man 60man is offline
I have to ask why? Is it a idle problem with a big cam? Going to raw vacuum and more initial will help. With the granny gear first it should launch well..
I have heard of guys messing with internals....
ECM member.
MANDRA
Old 07-11-2019, 06:59 PM
389 389 is offline
There is no converter.
Look on e-Bay for the 1963 Bonneville 421 Tri power governor.. It works perfectly with the 068 cam which is all you really want with that combo. Its a very nice combo..
Don't get talked into the th400 swap by some drag racer, the Super Hydro is a blast on the street.. Its a very strong and efficient transmission..
