Old 05-19-2019, 03:19 PM
konwal455gto konwal455gto is offline
Default Speedometer adapter
I just installed a 2004r in my 65 Gto. Speedometer is way off. is reads as follows .
Speedo garmin
30 reads 25
40 32
50 38
60 46
70 55
80 61
90 70
What adapter do I need ? I think that it will have to a 90 degree for space reason. Where can I get one for the best price Thanks Bill
Old 05-22-2019, 07:43 PM
lust4speed's Avatar
What tire size and rearend ratio? Have you checked what size drive and driven gears are currently in the trans?
Mick Batson
Old 05-22-2019, 08:02 PM
pgp66's Avatar
pgp66 pgp66 is offline
Try this one, just need rear ratio and tyre size: http://www.montess.org/speedo_gears.html
And gears are available from here: http://www.ckperformance.com/List/20...ars-Components
--> 1966 Pontiac Le Mans Convertible, Martinique Bronze, black top, Parchment interior, alloy Rallye 2's, M/T Sportsman ST's 235f/255r with redlines, 464 (455 .040 over), Performer RPM 87cc round port heads, Butler roller cam, Edelbrock Pro-Flo 4, Ram Air 2.5" manifolds, 67 GTO Ram Air pan, 2.5" Magnaflow, Muncie M22, 3.55 Eaton Posi. <--
Old 05-22-2019, 09:21 PM
pastry_chef's Avatar
Originally Posted by konwal455gto View Post
90 70
Just going by this and making many assumptions.
3.42 rear axle
tire diam 26.8 inches
drive gear 13
driven gear 26
--- IF those are what you have swapping to a 10 drive gear will put you real close, just over 1% error.
Old 05-22-2019, 09:32 PM
Default Adapter for speedo
Called Art Carr at California Performance Transmission , He just needed what the speedo said when my garmin read 50 mph $75 Life is good Thanks for the replies . Bill
