1982-1992 TA & FB parts FOR SALE 1993-2002 TA & FB parts FOR SALE is now part of the new Late Model Section of the PY Forums. Click this link to check it out.
Old 06-13-2019, 12:03 AM
TB1's Avatar
TB1 TB1 is offline
Default Dual pattern bell housing.
Casting Number 14037657 Dual Pattern Bellhousing
Correct for 1982 F Body (Camaro/Firebird). Will work with a Buick, Olds, Pontiac or Chevy engine, with 153 tooth flywheel and small starter
Small hole drilled in bottom for inspection port by previous owner. I installed heli coils in the mounting points. Can send more pictures. Located in BC CANADA. Looking for $125 plus actual shipping.
65 LeMANS , SD performance 462ci Engine, Tremec TKX 5 speed with a 3.73 geared 8.5" 10 bolt
