Old 06-21-2019, 10:56 AM
455TA's Avatar
455TA 455TA is offline
Default New Personal Best - 462 Pontiac
As the title says, made my new personal best pass on last Friday night at TNT.
I ran a 1.49 to the 60' and 7.08@94.6 mph to the 1/8th, 11.17@119.8 in the 1/4 mile.
1980 Trans Am - 3800 lbs, 455 w/ stock crank & rods, arp bolts, TRW pistons, round port E heads that flow 307@700, CR comes out to 9.57:1. XR288HR-10 comp cam Hyd Roller(236/242@050, 600/620 lift, 110 LSA) 1.65 HS rockers, Performer RPM intake, FiTech EFI.
Th400, 10 Inch 3400 Converter from UCC, built 10 bolt with 3.42 gears, all on 89 pump gas.
My plan is to swap to a ported Torker II intake with a Wilson 4 hole tapered spacer and see if I can get it in the 10's!
1980 Trans Am - Street/Strip 462
Best: 7.08@95 with 1.49 60' in the 1/8th. 11.17@119.8 in the 1/4. N/A, 3700 lbs, 3.42's, Pump Gas.
Admin of Pure Pontiac Powered Outlaws on Facebook.
Old 06-21-2019, 11:05 AM
Skip Fix's Avatar
Skip Fix Skip Fix is offline
Good job!
Skip Fix
Old 06-21-2019, 11:22 AM
Scott Stoneburg's Avatar
Scott Stoneburg Scott Stoneburg is offline
Nice! Always feels good to get a personal best. 60' number is great. Good luck with the intake/spacer swap. Should get you where you want to be
Old 06-21-2019, 11:54 AM
adam woodmancy's Avatar
adam woodmancy adam woodmancy is offline
Send a message via AIM to adam woodmancy
awesome, congrats!
1972 Pontiac LeMans
Thanks to
Fuelab Digital Fuel Delivery
Quarter-Max Chassis and Racing Components
Old 06-21-2019, 12:09 PM
steve25 steve25 is offline
Good job there!
Is the car legal to run in the 10's, as you know they will bounce you out after one or two passes ya know!
The Plenum is kinda shallow in the T2 so with your cubes I think you will find faster times with a open spacer, though street driving would be better with a 4 hole.
Old 06-21-2019, 12:12 PM
Scott65's Avatar
Scott65 Scott65 is offline
Nice work. Nice car too.
Old 06-21-2019, 12:44 PM
Skip Fix's Avatar
My TA ran 10.90s @123 and 6.90s @ 99-100 with a slightly slower 60 ft so you should be there easily. One track it was no big deal, San Antonio nicely told me to slow it down, Dallas track not so nice.
Skip Fix
Old 06-21-2019, 02:10 PM
455TA's Avatar
Good job there!
I have an open spacer that I blended into the plenum of the TII that I want to try out as well.
I'm nowhere near legal to even run what I run now, but it's Alabama and we could run 7's in the 1/4 and they'd never even check the car. lol.
Old 06-21-2019, 02:12 PM
455TA's Avatar
I guess my car just makes a ton of torque and is lacking slightly on the top end, possibly from the performer rpm? Just based on mph anyways. I have ran 96 in the 1/8th but I think it was better DA that night.
Old 06-21-2019, 02:56 PM
PAUL K's Avatar
PAUL K PAUL K is offline
You should've told the Dallas track who you are.
Go fast, see Elvis!
Old 06-21-2019, 03:14 PM
Skip Fix's Avatar
Paul and that was even at the Pontiac Southern Nationals. It was a time trial and Mike Cooke in his red 73 pulled me a fender on the top end. His car was in Pontiac Enthusiast years ago. The Houston track in the past is really pissy even if you are 0.1sec fast. They have a new crew now so not sure how they are, the only tech the Good Friday I ran there recently was "you got all the right tech stuff? OK" Camaro does so not issues.
Skip Fix
Old 06-21-2019, 04:39 PM
Rocky Rotella's Avatar
Rocky Rotella Rocky Rotella is offline
Impressive numbers!
Do your E-heads 1.66 or 1.77" exhaust valves? Was any modification to the TRW piston valve relief required?
Old 06-21-2019, 05:00 PM
pastry_chef's Avatar
Darn good for 9.57 compression. What size header? dual 3 inch pipes?
Ported T2 with spacer would be a great match.
Old 06-21-2019, 05:49 PM
Half-Inch Stud's Avatar
Whoa hey, before you switch to a TII, what intake did that? ?
12.24/111.6MPH/1.76 60'/28"/3.54:1/SP-TH400/469 R96A/236-244-112LC/1050&TorkerI//3850Lbs//15MPG/89oct
Old 06-21-2019, 09:37 PM
scott70's Avatar
scott70 scott70 is offline
You gained 25 mph from the 1/8th to the 1/4 which is a good gain for the 2nd half of the track.
1970 GTO 455 4 speed #matching,, 3.31 posi.Stock manifolds. # 64 heads.A factory mint tuquoise ,69' judge stripe car. 8.64 @ 87.3 mph on slippery street tires.Bad 2.25 60ft.Owned since 86'
Old 06-21-2019, 10:24 PM
Scott Roberts Scott Roberts is offline
Obviously, they had no idea he was in the Ehead Mafia....
Old 06-22-2019, 01:59 AM
Dragncar Dragncar is offline
T2 might like a open spacer with the 4 hole Wilson on top of it. If you have the room. I have had good luck with doing that.
A Tomahawk intake works real well for what you are doing too. Fits perfect for shaker hoods.
Did you ever build that engine you were planing on ?
Old 06-22-2019, 03:02 PM
OCMDGTO's Avatar
OCMDGTO OCMDGTO is offline
Awesome numbers for your weight and cam and best numbers I've heard of with the XR288. I would try a 1" open spacer w the T2, my engine made more power with one vs a 4 hole Wilson. What is your suspension set up to get that 60' time?
Chris D
69 GTO Liberty Blue/dark blue 467, 850 Holley, T2, Edelbrock Dport 310cfm w Ram Air manifolds, HFT 245/251D .561/.594L, T400, 9" w 3.50s 3905lbs 11.59@ 114, 1.57/ 60'
Old 06-24-2019, 07:38 AM
455TA's Avatar
Originally Posted by Rocky Rotella View Post
Impressive numbers!
They are 1.77's. No modifications required - as a matter of fact there was .170 of valve clearance with the 1.65 Harland sharp rockers on both valves according to my dial indicator.
455TA's Avatar
That's with a Performer RPM that I ported to match my heads - no spacer.
