1982-1992 TA & FB parts WANTED 1993-2002 TA & FB parts WANTED is now part of the new Late Model Section of the PY Forums. Click this link to check it out.
Old 06-23-2019, 01:38 PM
shakerz's Avatar
shakerz shakerz is offline
Default Any 350/400/455 brackets and pulleys
will buy all reasonably priced
Thank you -call/pm/text
steve
806-433-7469
70 lucy auto t/a, 70 polar 4 speed no air t/a, 78 y82, 79 y84
Old 06-23-2019, 03:32 PM
Scott Thelander's Avatar
I have a milk crate of 71 n newer pulleys I will never use
what year are you needing
I have later power steering pump n pulleys n brackets tooo
Old 06-23-2019, 03:44 PM
shakerz's Avatar
Hi Scott I don’t need the pumps. What would you take for the crate?
Old 06-24-2019, 12:08 AM
Default Hello
sorry for the delay ....
had to pallet up some 71 stuff
and get some gauges out
and box up a bunch of bolts and hardware
but heres the pile of pulleys ... qty on top of each
open to an offer ...
shippings probably 35-45 fed ex probably 35 lbs
Scott
2o6 465 9165
1 crank pulley has a fixable boing on the lip ... other pulleys are fine
ID:	514719   Click image for larger version
ID:	514722   Click image for larger version
ID:	514723   Click image for larger version
Old 06-24-2019, 07:01 AM
shakerz's Avatar
Thanks Scott did you say you had brackets too?
Old 06-24-2019, 09:59 PM
I have a 71 72 power steering pump n brackets .... no C bracket 481042 pulley
a 73 74 493243 pulley and pump and brakets ... no C bracket
a 75-79 496411 pulley and brackets no C bracket for the alter nator ...
i have an 80 amp alternator mount and a later alternator mount
Scott t
2o6 465 9165
ID:	514776   Click image for larger version
