Old 07-13-2019, 10:46 AM
Ziggy Ziggy is offline
Default 1963 Overlapping Wipers resting vertically.
I just finished disassembly and reassembly of my 2 spreed 1963 overlapping wiper motor and pump assembly. The motor and rebuild pump work fine. After multiple try’s I finally got the wiper blades to overlap without hitting one another and sweeping the windshield properly. However, they will not “horizontally park” and are parking “vertically “.
How do I correct this.? Am I out 180 degrees on the motor arm level to linkage hookup? Any insight would be thanked!
Old 07-13-2019, 12:05 PM
hobbygto65's Avatar
hobbygto65 hobbygto65 is offline
Can't you just take them off and put them back in the horizontal spot with wipers set in park?
Old 07-15-2019, 07:43 AM
Then the arms would then try to sweep down over the window base chrome trim. I think my only alternative would be to remove motor/pump from firewall and jog motor arm to a position of 180 degrees out.
