Old 07-17-2019, 07:53 AM
mysticmissle's Avatar
Default IA2A aluminum wet deck builds
finally got around to dropping my stuff off at machine shop yesterday. Machinist had a bunch of questions. I had talked to Bob C and he said cometics with the small water holes are doing quite well. Talked to Jeff V and he prefers dry decking and titan copper.
Its going to be a bracket motor 850-900 hp, what is currently being run on aluminum block 4.350 bore and 14:1 compression range. I have a set of wet deck wide ports i plan on using for the first season or two, and i could dry deck them if i go that route, and then i will uncork it and either have them worked up or put some heads that flow on there.
thanks in advance.
Old 07-17-2019, 10:24 AM
Jack Ferris's Avatar
Jack Ferris Jack Ferris is offline
May be a silly question. My IAll is not drilled but the heads are. Do you have to plug the head as well?
Jack Ferris
RestoRacing LLC
www.restoracing.com
Sandy, UT
Old 07-17-2019, 10:40 AM
yes or you drill and make the block wet also, Frank said to use a 5/16'' bit i beleive, just need to make sure the hole matches your gasket location
Old 07-17-2019, 10:51 AM
twooldgoats's Avatar
twooldgoats twooldgoats is offline
That's what Paul Carter did with mine to dry deck it. A lot of holes to weld in those heads and they had to be re-surfaced and made straight again. Then, he used copper gaskets and O-rings. So far, it works. I run water in the heads only, not the block.
Jim
****'63 Tempest, 475" IAII, Wenzler Super Chief heads, converted to blown alcohol, Birdcatcher, Littlefield 10-71 high helix. Best pass to date: 7.67 @ 181.59 (1/4 mi.), 4.95 @ 143.67 (1/8 mi.), 1.18 (60 ft)
7.75 @ 178 pass:
https://www.youtube.com/watch?v=Iez3...ature=youtu.be
First seven second pass(7.98): https://wwwoutube.com/watch?v=DK17...ature=youtu.be
Thanks to Paul Carter @ Koerner Racing Engines
The Following User Says Thank You to twooldgoats For This Useful Post:
Old 07-17-2019, 09:17 PM
Richie Hoffman's Avatar
Richie Hoffman Richie Hoffman is offline
I’m building a aluminum block for customer street car going to be turbocharged doing a wet deck not gonna get crazy on boost
2008KRE Q16 Winner
2014 atco raceway doorslammer winner 86 grand am tube car 8.95 @152 455 eheads solid flat tappet cam
Hoffman Racing building and racing Pontiacs for 35 years
Old 07-17-2019, 10:38 PM
BADDTA's Avatar
BADDTA BADDTA is offline
Hey Jeff
We have Jakes aluminum block wet decked. We plan to push 4-500 thru it also. Using Cometics also. I didn’t have time to pick it up yet for assembly. Been done for a while. Work is crazy busy.
Brian
Boobs & bacon
Old 07-18-2019, 07:34 AM
taff2's Avatar
taff2 taff2 is offline
No need to weld up the coolant holes, drill and tap them for pipe plugs and then get them surfaced, it's what I did to my factory heads and block. If you ever decide you want wet deck then just remove the plugs.
Old 07-18-2019, 07:51 AM
Brian and Richie, you guys plan on using cometics? what bore?
Old 07-18-2019, 08:15 AM
Cometics block will be 4.250 bore
2008KRE Q16 Winner
Old 07-18-2019, 08:29 AM
BADDTA's Avatar
4.350 bore and Cometics
Brian
Boobs & bacon
Old 07-18-2019, 09:07 AM
thanks guys, Richie, you prescribe to the 5/16'' cooling holes?
Old 07-18-2019, 10:39 AM
Been using 1/4 on big bore stuff
2008KRE Q16 Winner
Old 07-19-2019, 09:30 PM
PontiacMatt72's Avatar
PontiacMatt72 PontiacMatt72 is offline
If you decide to dry deck, X2 on tapping for pipe plugs and install *aluminum* plugs. I used a high temp thread sealant on the plugs also.
Another method suggested to me was install a tapered press-in style plug?
Either way, after plug is in place, have head surface machined flat. Good to go. In my case, this process took off enough of some of the plugs that they won’t be easily unscrewed. But I imagine wouldn’t be much trouble to drill back out if need be.
As for whether to run wet or dry deck, I chose dry... and hope it was the right choice. I have an iron IA2. My choice was based on the potential for adding boost or nitrous later.
Probably not much help. Just sharing.
Matt
70 GTO 400 4-speed
"Turbos make no noise and leave the line like Baby Diarrhea!" - GTOGeorge
Old 07-19-2019, 11:50 PM
RAIV-Z's Avatar
RAIV-Z RAIV-Z is offline
Jeff,
Dry deck it, external cooling lines work. Either plugs or welding the heads/block will be fine.
2023 Best ET Slip
60’ 1.224
330 3.186
1/8 4.784
MPH 152.07
1000 6.175
ET 7.347
MPH 189.92
Weight 3650
Old 07-20-2019, 08:32 AM
jimmy daniel's Avatar
jimmy daniel jimmy daniel is offline
My block and Tigers are dry decked and plumbed from rear of heads to back of block. Seems to work real well. My block was never drilled and the heads have plugs in them
1965 TriPower GTO, 1967 GTO, 1969 GTO, 1969 Judge, 1972 GTO, 1977 Smokey and the Bandit, 1989 TA ProStreet, 1968 Firebird NHRA 10.90 racecar, 1963 Tempest S/Gas
Old 07-20-2019, 09:22 AM
73 TRANSAM 73 TRANSAM is offline
I have a dry deck and reverse cooled on my turbo set up. I like it as its not messy when u need to pull out the heads and a big plus is you don't get any water in your cylinder on PA application incase your heads lifted.
Old 07-12-2024, 02:01 PM
adam woodmancy's Avatar
adam woodmancy adam woodmancy is offline
Send a message via AIM to adam woodmancy
i am planning on doing an aluminum 482 bracket/limited street shortblock this winter. I am not looking to make big power, mostly, just looking for the weight off the nose and reliability. I will be reusing my 340 std port e-heads and using a scott brown hydraulic roller. The couple guys that I know personally using the aluminum stuff are dry decking them, but I was hoping to keep this build as standard possible. As I said, my car worked great with my 400 block setup, and I think would work even better with the weight off the nose from the aluminum block. (stock suspension/9" radial) I do not under any circumstance want to out and Iron IAII or MR1 in it. If the aluminum block doesn't seem like a smart way to go with the wet deck setup, I will use another 400 block. I am happy with the power where I am already, as I said, just trying to ditch as much weight up front as possible. Motor will be n/a, probably make 650-700 hp tops.
Old 07-15-2024, 04:17 PM
Bill Eveland's Avatar
Bill Eveland Bill Eveland is offline
FWIW My ia2 iron block is 4.350 and wet decked, i used the cometics with copper spray from Butler as a drill guide. 14:1 380 highports. Have to keep in mind the thickness of the sleeves , so slightly offset holes in that hole range are better to keep the drill bit away.
Illinois Outlaw Gassers
6.27@107
9.97@131
The Following User Says Thank You to Bill Eveland For This Useful Post:
Old 07-16-2024, 07:47 AM
aaronman aaronman is offline
We have built two MR1A wet deck 535 bracket engines. Both around 900hp with KRE high ports and cometics. Both engines have went 250 passes between tear downs. No issues. Cools really nice. I don’t recall the deck hole size. They were drilled at KRE.
The Following 2 Users Say Thank You to aaronman For This Useful Post:
Old 07-16-2024, 04:39 PM
Skip Fix's Avatar
Skip Fix Skip Fix is offline
Mike had some pictures of drilling the holes on their road race aluminum black a year or so ago. Some larger material for head bolts in the bloack made some head gasket locations had to have to be off center.
Skip Fix
