Performance Parts For Sale/Wanted Just Performance, non-stock, trailers, tools and related accessories here.
Old 07-19-2019, 10:54 PM
gata79 gata79 is offline
Default Forged crank
Brand new Eagle 4.5 stroke crankshaft. Unused. 3 inch mains. 2.2 rod journals. Dimensions checked. Ready to bolt in. 650 plus shipping. I’m going turbo so bought a 4 inch crank.
Old 07-20-2019, 07:26 AM
HoneyHush HoneyHush is offline
Pm sent
Old 07-20-2019, 10:09 AM
Didn’t get it
Old 07-29-2019, 06:43 PM
Bump
Old 08-08-2019, 06:35 AM
A couple of pictures
ID:	517268   Click image for larger version
Old 10-05-2019, 08:29 PM
Pm sent to you again.
Old 10-10-2019, 02:39 PM
Bump
Old 10-11-2019, 02:14 AM
turbo69bird's Avatar
Just curious why you'd go 4 inch for turbo?
Turbos make big torque you basically trick the engine into thinking it's twice the cubes at 15 psi so more torque x 2 is better, more cubes x 2 is better. Don't believe the hype bigger stroke means you can shift lower cycle less and therefore stress the block less and cycle the engine less adding life to the engine, you can also use lower numerical gears w taller tire and load the turbos harder, the harder you load it the more it works. Think loaded tractor trailer and that boost sound. That's why you see guys running3.08 gears tall tires and glides.
I hear a lot of stupid hype about smaller motors for turbos. Makes no sense at all.zero.
960 HP @ 11 psi, 9.70 at 146.
