Tri-Power Tech 57-66 Tri-Power Talk
Old 07-28-2019, 04:21 PM
dbiggs dbiggs is offline
Default Any tripower specialists Central FL?
Recently tried to start car after sitting for 4 years...front carb started leaking around shaft a little. I cranked the car again and there came gas flying out of the carb. anyone in Central FL area that rebuilds these carbs...or is there anything simple I can check? Ran fine 4 years ago...maybe something hung up in there or clogged?
Resto almost done - 1966 GTO HDTP Tiger Gold (paint code 1-2), black vinyl top and interior, 389 tripower, 068 cam, TH-350/Hughes TC, RA manifolds, 2.5" Pypes exhaust, Scarebird Front Disc, Ralley II's, factory PS, PB, PW, PA, A/C, headrest option.
Old 07-29-2019, 11:03 AM
Dick Boneske's Avatar
Problem is simple. The needle/seat is not shutting off gas at startup. Pulling the top off the front carb and replacing the needle/seat is not difficult. PM me if you want a new needle/seat & gasket before you begin.
BONESTOCK GOATS
'99 Bonneville SE Sedan
