Old 07-29-2019, 01:06 PM
CraigG.'s Avatar
CraigG. CraigG. is offline
Default Gloves for adjusting hot valves
Hey Everybody,
Little question - What gloves do guys like for adjusting hot valves?
Thanks, Craig
Old 07-29-2019, 01:47 PM
Gloves?
Old 07-29-2019, 02:05 PM
oldblueponcho's Avatar
oldblueponcho oldblueponcho is offline
Originally Posted by Chief of the 60's View Post
Gloves?
X2.
Some Fear, Because if you've never been afraid- just a little. You're obviously not going as fast as you could be.
Old 07-29-2019, 02:08 PM
Scott Stoneburg's Avatar
Scott Stoneburg Scott Stoneburg is offline
No gloves here. How hot are you getting it to adjust the valves? I adjust mine between 160-180. I do one side, restart the motor to keep the temp in that range and adjust the other side.
Old 07-29-2019, 02:21 PM
Does it matter? Skin does not come in contact. Unless you are adjusting valves on an old flathead and even then you use tools.
Old 07-29-2019, 02:30 PM
John Langer's Avatar
John Langer John Langer is offline
No gives while adjusting the valves but wear mechanics gloves when I pull the plugs. They get pretty hot.
Old 07-29-2019, 02:57 PM
lakefect lakefect is offline
why even do it hot, set it once hot then check cold after that you can do it cold always
Old 07-29-2019, 05:32 PM
GTOGEORGE's Avatar
I always do mine COLD!
GTO George
Old 07-29-2019, 06:44 PM
Skip Fix's Avatar
Skip Fix Skip Fix is offline
GTO George
I do a couple hot then measure them cold and do them all cold. I figure by the time I get to the last ones they are not as hot as the first ones-and my hands are not as toasty!
Skip Fix
Old 07-29-2019, 09:47 PM
Scott Roberts Scott Roberts is offline
Smh... wtf. Sell your car and buy a Prius..
Old 07-29-2019, 11:22 PM
CraigG.'s Avatar
OK guys I deserve that - I guess that I am getting a little white collar-ish! LOL! Pruis?????
I never have used gloves to work on anything ever and for the first time I am buying gloves to protect me now because of all the carb cleaners and solvents used over the years - doc says not cool and may have caused some health issues - most breathing problems. Yes, running valves in the pits I do remember that the plugs get hot. I will buy some nitrile gloves for cleaner use.
Thanks and Take Care, Craig
Old 07-30-2019, 09:02 AM
Old 07-30-2019, 10:08 AM
chiefbigb chiefbigb is offline
I took a ride in a Tesla. It was pretty fast and requires no valve adjustment.
Be carefull of the feet you step on today.They may be attached to the a$$ you kiss tomorrow.
Old 07-31-2019, 09:20 AM
J.C.you's Avatar
J.C.you J.C.you is offline
Best I have used are the gorilla grips for wrenching. Get them on the smallish side for your hand size. They stretch.
1966 GTO dragcar
1966 GTO Ragtop
1969 Tempest ET clone street/strip
1969 GTO Judge RA lll, auto
1969 GTO limelight Conv. 4speed go and show (sold)
1970 GP SSJ
1972 GTO 455 HO, 4 speed, (build)
Old 07-31-2019, 07:07 PM
Skip Fix's Avatar
My IT guy 's dad has a Tesla, several Prowlers, Vipers and a GTO). The dad developed something like the bank drive-in vacuum tubes so dad is well off. He said the Tesla has all the power as soon as you hit the gas.
Skip Fix
Old 08-01-2019, 10:32 AM
Sad to say the thing was pretty impressive.
