Old 08-07-2019, 07:20 PM
kylek350's Avatar
kylek350 kylek350 is offline
Send a message via AIM to kylek350
Default Same 9.5" Brake Drums for 10 & 12-Bolt Rear Ends?
Are the same 9.5" Drums used on both the 10-bolt and 12-bolt rear ends?
Kyle Kruszewski
  • 1970 Tempest Post Coupe - Baja Gold, Green interior, 350/TH350 - (1?)32k miles, original condition barring repaint
  • 1970 GTO - Granada Gold, Sandalwood, factory 455/M-21 - Awaiting restoration
  • 1951 Chieftain Deluxe Eight 4-Door Sedan - Saturn Gold, Hydra-Matic - Hibernating since 1969
Old 08-08-2019, 09:53 AM
Murf Murf is offline
I believe they are. When I changed my Firebird from a stock 10 bolt to a 12 bolt, I don’t remember getting different brakes. I ‘m pretty sure I just swapped them over.
It was 20 yrs ago, tho
Murf
Sent from my iPhone using Tapatalk Pro
Old 08-08-2019, 10:07 AM
kylek350's Avatar
Thanks, Murf! I’m pretty sure they’d be the same, but just checking.
Kyle Kruszewski
Old 08-08-2019, 10:36 AM
I should add, I swapped backing plates & drums over while changing rear ends.
Old 08-08-2019, 10:46 AM
Sirrotica's Avatar
Other than the different divisions used different cooling fin designs, I believe that tons of GM cars used 9.5, 5 X 4.75 bolt circle drums than interchanged. 10 and 12 bolt should make zero difference.
Brad Yost
1973 T/A (SOLD)
2005 GTO
1984 Grand Prix
Old 08-08-2019, 10:56 AM
kylek350's Avatar
Thanks, Sirrotica!
Kyle Kruszewski
Old 08-09-2019, 07:35 AM
chrisp chrisp is offline
No there is 2 different size register holes.
Old 08-09-2019, 10:59 AM
Tom Vaught's Avatar
Boost Engineer
I believe that only applies if you are swapping Chevy 12 bolt vs Pontiac 10 bolt.
If you have a 70-72 Pontiac 12 bolt rear axle and swapping 10 bolt for 12 bolt, it should be a exact interchange, IF I remember the one 12 bolt rear I had under by GTO.
Course that was the 12 bolt that blew up like the 10 bolt rears too.
Tom V.
Old 08-09-2019, 11:18 AM
Sirrotica's Avatar
How is it that the wheels interchange between the two, but brake drums won't ?
Looking at brake drum specs the center hole is within 1/100th of an inch, 2.81 vs 2.82. A rat tail file and 2 minutes will make them the same ID. Rust on an axle flange is many times more than .01 thick, a rat tail file will make short work of that slight interference.
Brad Yost
1973 T/A (SOLD)
2005 GTO
1984 Grand Prix
Old 08-09-2019, 01:29 PM
HWYSTR455's Avatar
It's the housing tube flange that can be different, due to the tube diameter, which would impact the backing plate fitment. It would look like crap if you tried to wobb it out with a file.
Drums can be slightly different, the depth/axle stand off, but in most cases will 'work'.
EDIT: Have to make sure it's not an 'O' 12 bolt too.
ID:	517350   Click image for larger version
Old 08-09-2019, 02:42 PM
Sirrotica's Avatar
NO... it's the center hole on the brake drum that is .01 difference.
OPs original question is:
Not sure how backing plates got into the conversation, or how you turned my statement into opening up the backing plate holes with a file. Pretty sure my statement was the center hole in the brake drum could be opened up .01 if need be.
Brad Yost
1973 T/A (SOLD)
2005 GTO
1984 Grand Prix
Old 08-09-2019, 04:02 PM
HWYSTR455's Avatar
Guess I didn't read carefully, my bad. I was thinking along the lines of swapping the complete brake setup over from rear to rear, and apologize if it came across as an attack.
Old 08-09-2019, 06:55 PM
That’s my fault, guys. I mentioned them in my reply. Sorry if I drove this thread into the ditch!
Old 11-22-2019, 10:27 PM
Filthy frank Filthy frank is offline
Default Rear axle register
Good question ! Now i have to go measure the register on the 12 bolt axles i made when i owned summers bros and the center of the 11 inch impala rear drum set-up with housing ends i made for a big ford bearing !
Old 12-10-2019, 05:04 PM
hobbygto65's Avatar
hobbygto65 hobbygto65 is offline
Just some info, S10 rear brake drums are the same as 8.2. They even have the same part number.
The Following User Says Thank You to hobbygto65 For This Useful Post:
Old 12-12-2019, 02:35 PM
jerry455 jerry455 is offline
I upgraded my rear brakes from the 9.5 drum set up to the 11" drums for my 1976 Firebird. I did the 1LE front set up and used the 11" rear drum set up form a 1977 Lemans. Went up an inch in the front and 1.5" in rear. Works great.
Old 12-12-2019, 02:49 PM
I made impala housing ends to adapt 11 inch drum brakes and big ford bearings and made chevy c clip eliminator axles when i owned summers bros for my 63 nova , but sold the nova and im setting up a chevy rear end for my 63 lamans !
